Old 06-16-2017, 06:19 PM   #1
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
BRZ aerial connector
Need a little help please. I've got a 2015 BRZ and I've just fitted an aftermarket radio. I can't source an aerial adapter. The BRZ has a strange square connector and the Sony unit the usual DIN thingy.
Anyone know what I should be asking for?
Scrappydoo is offline   Reply With Quote
Old 06-16-2017, 08:04 PM   #2
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
You need this:
https://www.crutchfield.com/S-LAUHnH...a-Adapter.html
Splice the blue wire of the adapter into the blue "remote" wire of the aftermarket wire harness.
Helios is offline   Reply With Quote
The Following User Says Thank You to Helios For This Useful Post:
Scrappydoo (06-24-2017)
Old 06-17-2017, 11:37 AM   #3
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Originally Posted by Helios View Post
You need this:
Cheers. I've got one of those but where does the white plug plug into?
Old 06-17-2017, 07:49 PM   #4
navanodd
Drives: 2013 BRZ Sport-tech WRB
Dig around the dash a little bit, you should definitely have the mating plug for the white part of that adaptor.
Sony XAV-AX100?
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
Old 06-17-2017, 07:53 PM   #5
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Sony XAV-AX100?
No. It's much smaller. I'll try and dig out a photo.
Old 06-17-2017, 08:01 PM   #6
navanodd
There is a similar but smaller connector that I believe is for reverse camera hookup.
Old 06-23-2017, 06:37 PM   #7
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Yes I've just twigged and found the correct connector. What is the blue wire for? Is the aerial powered?
Old 06-24-2017, 03:32 PM   #8
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Another light bulb moment. Connected the blue to the switched live and bingo. Radio stations.
Whats the name of this connector (3rd brake light connector) Chimera Cosmetic Modification (Interior/Exterior/Lighting) 4 01-10-2017 06:13 PM
Shark Fin Aerial and K&N Tornado Intake Stan AFRICA 0 05-18-2016 01:31 AM
Aerial lap of TMP wparsons CANADA 18 06-23-2015 12:48 PM
Aerial Video Footage - DriftWest 2013 OICU812 CANADA 3 09-30-2013 09:53 PM
DriftWest Aerial Footage - Edmonton,AB, Canada OICU812 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 09-29-2013 10:21 AM
