Drives: 2017 BRZ SP
Clutch Spin Down Time
I think this is called clutch spin down time...
Had my BRZ for almost a month now and I was surprised at the level of gear crunch when going into first. What is others' experience with this? Is it normal for this tranny? The car was brand new special order, so I know no one beat on it during test drive. It's only a slight crunch, but in my experience almost no other cars do this, especially not a brand new one. Basically if I am in neutral, then push the clutch in and go into 1st within a second (or reverse for that matter) it isn't totally smooth and there is a much more noticeable "notch", maybe crunch is too aggressive of a word. I have learned to wait a few seconds after pushing in the clutch before goign into gear and then it is fine. My previous car was a '01 Sentra with 220k miles, and it, amazingly was buttery smooth by comparison, no need to wait at all. ..Side related question....is the reason our cars are "notchy" a price to pay for some more durability as compared to a basic economy car like my 'ole Sentra? |
Drives: frs
Try rev match
Drives: 2014 GT86
Given 1st gear mention .. maybe your described noises are from diff preloading?
There are many noises in this car compared to some generic family car. Tranny, gearbox, road noise, high pressure fuel pump chirps, some interior bits rattle. To keep weight & price down it's short on noise insulation. I still love this car even despite some shortcomings. |
Drives: 2013 FR-S Series 10
My first gear is very smooth. I am assuming you are at a dead stop or coming to a dead stop when doing this? How's your third gear? Something I get a notchy third gear shift, but its one of those "it is what it is" things IMO with these cars.
Considering your car is a month old, it still needs quite a bit of time before it breaks in. |
The tolerances on are tight in this transmission, in time it will loosen but not much.The shifts 1>2>3 can be notchy. Change out the trans fluid to Motul gear fluid and you'll be fine.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
not playing cards
Quit double posting.
Yep, @ChRZ ...... we heard you the first time.
It ain't nice to try to confuse us old men ..... ![]() humfrz |
[insert cool phrase here]
Drives: BRZ Premium
Ok here the deal, our trannys suck when cold every 1,2 maybe 3 will grind a tad.
Our tranny oil sucks. As many people have done and reported good/better shifting with better tranny fluid. Although cold start up do grind. That's petty much it. Out trannies just suck.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following User Says Thank You to Mr.ac For This Useful Post: | daskaman (06-11-2017) |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
You're talking about the 'clunk' when stopped and shifting into first from neutral... just put clutch in and don't shift into first right away. Like when the light turns yellow put the clutch in then just before green shift into 1st. Problem solved.
Also I don't think smooth is the right word for FWD transaxle shifters, the words 'floppy' and 'jello' comes to mind, way too much play in neutral, even in the Honda's and Acura's I've had. With a proper gearbox transmission in a RWD sportscar you get a very precise and positive shifting feel, which the FR-S has. If you want a buttery 'smooth' RWD shifter that shifts itself and avoids neutral like it has a disease, the ND MX-5 is your ticket...personally can't stand the ND MX-5 shifter at all....very frustrating feeling to me.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
#10 | |
Drives: 2013 Subaru BRZ
Shift quality improves steadily over the first 20,000 miles. |
#11 | |
#12 |
#13 |
Drives: 2015 Series.Blue
Normal.
Heavier gear pack + larger clutch = more inertia |
#14 | |
![]() humfrz |
| Throwout bearing/clutch fork repair completion time | ARTBRZ | Issues | Warranty | Recalls / TSB | 19 | 01-28-2017 09:28 AM |
| Replace Clutch or Time to Upgrade? | Antialias | Issues | Warranty | Recalls / TSB | 9 | 11-19-2016 08:44 PM |
| WTT: White delron BeatRush spin turn knob for red aluminum Cusco spin turn knob | SLVRSRFR | Canada Classifieds | 3 | 11-13-2015 03:45 PM |
| OEM Clutch Replace time | JRollar | Engine, Exhaust, Transmission | 18 | 06-19-2013 12:25 AM |
| out for a spin in OC/LA today | FRS714 | Southern California | 5 | 06-09-2012 08:40 PM |
