Old 06-01-2017, 10:15 PM   #1
brownwv
Drives: 2013 Subaru BRZ Limited Custom
EcuTek cable 13 BRZ
Club, just purchased a 13 BRZ with a supercharger and EcuTeck tuned on E85. Any way I can tap into the ECU with an different cable or something cheaper? I just want to see what the previous owner/tune shop did?
Thoughts?
brownwv is offline   Reply With Quote
Old 06-01-2017, 11:27 PM   #2
steve99
Thoughts?
Short answer NO
Long answer Most likely NO, but maybe
Ecutek like Brzedit changes the standard ecu access seed/key sequence so it can only be written to by ecutek or brzedit.
Both Ecutek & Brz edit don't have a ecu "read" function that produces a readable rom anyway.
This is to protect tuners work.
If and this is highly unlikely the original tuner wrote and ecutek tuned rom to ECU WITHOUT ecutek racerom features added then the seed/key will be standard and you could read it with a tactrix cable. Its the addition of racerom features that causes the seed/key change.
Even if you had the original file sent by tuner it will only have flash access with your ecutek kit, unless the tuner sends you an unlocked ecutek tune, highly unlikely.
The only thing you can do is log the ecu/tune and see the afr cam timing, ignition timing etc used at different rpm/loads. but you wont be able to see the actual tables. or anything like that in the actual ecu.
more info
http://www.ft86club.com/forums/showthread.php?t=106068
Old 06-02-2017, 09:39 PM   #3
brownwv
Thanks Bud, very helpful
ecutek brz frs, ecutek cable.
WTB:Ecutek cable rak.yury Want-To-Buy Requests 0 10-15-2016 04:39 AM
Ecutek Cable SunkenFRS Want-To-Buy Requests 0 04-27-2015 10:37 PM
Fs ecutek cable popos1907 Engine, Exhaust, Bolt-Ons 1 12-25-2014 02:35 PM
Wtb ecutek cable Jeong Engine, Exhaust, Bolt-Ons 6 10-25-2014 02:28 AM
wtb ecutek cable DTS Want-To-Buy Requests 0 01-10-2014 01:28 AM
