Old 05-31-2017, 02:51 AM   #1
amartinez9881@gmail.com
amartinez9881@gmail.com's Avatar
Drives: Scion FRS
tein Flex z or street basis ! (heLP!) ASAP
Hi huy si need your help!!
]I Was looking to get rid of my cars stock hight since I now have the rocket bunny v1 Kit but I can really only afford one of these to coilovers but I want to know one of two things . One wich one will get rid of my gap and leave perfect fit ment ( reference pic of hight I'd like below) and second wich ones can I convert to bags later on when I can afford it ( yes it can be done) see reference pic bellow plz help have Hot import night show in two weeks
amartinez9881@gmail.com is offline   Reply With Quote
Old 05-31-2017, 02:56 AM   #2
Drives: Scion FRS
https://ibb.co/bJUiYF
Old 05-31-2017, 06:50 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
I haven't ever bought/owned/driven air suspension, but have slight suspiction, that those airbags may have specific to them curves, that coilovers out-of-box valved for springs may match inadequately. If you are decided on air suspension, why one may need to stick to teins, of budget end at that? Better matching kit assembled of parts well working together.
Old 05-31-2017, 09:58 AM   #4
KnightRyderx2
Drives: 2014 FR-S
This link is the Tein Flex Z thread and there is a few pictures in there. I have them and my pictures are on the last page.
The rear is maxed out and the front can go another half inch maybe. That is with the proper preload setting. If I mess with preload to lower I can another 1" in the rear. The front cannot mess with preload to lower but I can remove certain collars and other things to get it lower, maybe another 1/2" on top of that 1/2" spoke of earlier.
As for the Basis Z there is pictures all over this site but they have a similar height. I was trying to decided between the Basis Z and Flex Z also a while ago, went with the Flex Z because that was the long term goal, and the adjustability.
You can get one of them now as a way to get the car low for the show and then sell them when to get yourself a proper airbag setup. You would have no problem in selling them as long as you take care of them. This is the route that I may take as I want my car on bags if I ever widebody. This was just a thought as it is your money and life so I'm not here to control what you do.
With that, I would say that you would have to go with the Flex Z as you would need a separated spring perch and top hat. Seeing as the Basis Z use the stock top hat this wouldn't work. To truly see what would work and not work you should contact that company to see what you can do, www.universalair.com. That is the company of the bags in the picture you posted.
KnightRyderx2 is offline   Reply With Quote
coilover suspension
Any experience with Tein Street Basis Z? Eight Sex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 02-20-2017 11:31 AM
(LA/OC) FS: Tein Street Basis xais Brakes, Suspension, Chassis 1 05-05-2016 06:07 PM
Tein Street Basis dito Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-12-2015 07:40 PM
FS; TEIN basis - best for street setup! hong Brakes, Suspension, Chassis 8 10-16-2014 01:58 PM
NY: F/S Tein Street Basis jammz Brakes, Suspension, Chassis 5 04-20-2013 09:31 PM
