Old 05-17-2017, 02:44 PM   #1
number_Un0
Drives: 2013 FRS 10 series #0001
Koni Yellow fitment with 45 offset RPF1
How's it going everyone!
I have a set of et45 rpf1's on my car with HKS sp coilovers.
I want to switch over to Koni Yellows (not sure witch springs I want yet) but im not sure if I will have and clearance issues on the inside with the Koni's.
If anyone can clear this up that would be awesome. I tried searching but nothing came up with the yellows.
I know with the stock shocks people have clearance issues with a 45 offset wheel. I just want to know if that's the case with the Koni Yellows as well or no.
Thank You.
number_Un0 is offline   Reply With Quote
Old 05-17-2017, 02:55 PM   #2
strat61caster
strat61caster's Avatar
What size is the wheel? 17x7 no problem, 18x10.5 is probably going to be an issue. Somewhere inbetween is a question mark.
ineedyourdiddly
Old 05-17-2017, 03:13 PM   #3
number_Un0
sorry, should have made that clear. The wheel is a 17x9
Old 05-17-2017, 04:00 PM   #4
strat61caster
This thread is pretty much mandatory reading as far as I'm concerned.
http://www.ft86club.com/forums/showthread.php?t=32719
Koni yellows are OE replacements, there should not be a significant difference between them and OE. You may need 3mm or 5mm spacers to get it to clear, could be harder if you're adding camber via camber bolts. Lots of pictures and feedback in that thread about how those wheels clear stock suspension but ultimately there's enough variance to not give a definitive answer.
I use 5mm spacers on mine to prevent rubbing at full lock (fender lining for me, not tie rod, lots of camber, I have coilovers and extended studs).
ineedyourdiddly
number_Un0 (05-18-2017)
Old 05-18-2017, 01:48 PM   #5
number_Un0
Thanks for the help, ill just end up running 3mm spacers most likely.
I was skeptical about tracking with spacers but I guess a bunch of people are doing it without issues.
WTB: Koni yellow with TRD springs Jack Black Want-To-Buy Requests 1 12-23-2015 12:07 PM
Fortune auto 500 coilovers vs. RCE Yellow springs + KONI Yellow shocks Kyogre Suspension | Chassis | Brakes -- Sponsored by 949 Racing 29 05-12-2015 04:59 PM
WTB: Koni yellow struts and RCE yellow springs nlowell Brakes, Suspension, Chassis 2 05-20-2014 03:10 PM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 10:32 AM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
