Old 05-12-2017, 07:14 PM   #1
xiaowudao
Drives: 2017 BRZ, 2016 Tacoma
2017 BRZ interior rattle
Hi all,
I have a 2017 sport tech, and have noticed a rattle from the passenger side speaker/dash area @ 4000-5000RPM . Took it to the dealer and they installed some foam in areas they thought it was coming from. This didn't help and the rattle continued. Couple weeks later I brought it back to the dealer, and this time they said they had to start a case w/ Subaru Canada to figure it out. They told me they test drove one of their new BRZs on the lot and it exhibited the exact same rattle, coming from same area passenger side speaker/dash. They also told me this might just be the design of the vehicle and nothing can be done about it. They did however take video of it and will send it to their report to Subaru Canada.
Anyone else noticing a similar rattle in their 2017s? Any advice on what I should do?
xiaowudao is offline   Reply With Quote
Old 05-12-2017, 07:44 PM   #2
Lynxis
Lynxis's Avatar
Drives: 2013 WRB BRZ 6MT
Originally Posted by xiaowudao View Post
Hi all,
My advise is to get used to it. All of these cars make various noises in various conditions. I can get a similar vibration at certain rpms/load levels from my dash. Also, I notice the plastic from the driver side dash rattles against something when it's really cold out, like -10 or less. Also, I have to remember to button the snaps on the seats that hold the seat belts because they will rattle if they're loose. Anyways, moral of the story is that these cars will make some noises.
Lynxis is offline   Reply With Quote
Old 05-12-2017, 07:47 PM   #3
Imrac
Drives: 13 SWP BRZ Prem
It's not only love that makes a Subaru a Subaru. It's also the rattles.
A common rattle I have found is actually the window buttons. Try reproducing the issue, grab a couple of sheets of paper, shove them between the button and the door card and see if that solves it.
Make sure the paper is large enough to remove easily, just for testing purposes.
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
Old 05-12-2017, 08:44 PM   #4
MarbleSoda
MarbleSoda's Avatar
Drives: 2016 Subaru BRZ
This happens in my 2016 BRZ-- Similar to you, I hear it on the passenger dash area. I've learned to get used to it, unfortunately. My buddy has the same issue with his 2015 WRX. Maybe it's a Subaru thing..
MarbleSoda is offline   Reply With Quote
Old 05-12-2017, 09:49 PM   #5
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Welcome to Subaru ownership, everyone I've owned rattled . (2 wrxs , 2twins ,and new gen xt)
Sent from my Pixel XL using Tapatalk
Ricepuddin is offline   Reply With Quote
Old 05-12-2017, 11:03 PM   #6
That is the only persistent rattle I had. Thought for the longest time it was the dash speaker cover. My grandson was riding once and figured out it was the A pillar plastic cover. I heated it up well with a blow dryer and gave it a firm push and held it until it cooled. Never heard it again. That was almost two years ago so I am optimistic.
Old 05-12-2017, 11:22 PM   #7
imprezza
Drives: impreza
Hi all,
I have a 2017 and have that exact same rattle... only when accelerating quickly i hear it. thought it was something in the glove box rattling but nothing
imprezza is offline   Reply With Quote
Old 05-12-2017, 11:27 PM   #8
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
I have one and heard it from day one. I know where it is. It's the stupid plastic dash rattling against the plastic of the infotainment system. If I push on it, it stops. I might try realigning it or putting some tiny foam in there.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 05-12-2017, 11:31 PM   #9
dostoyevsky
Drives: 2017 BRZ
Am I the only rattle free brz?
dostoyevsky is offline   Reply With Quote
Old 05-13-2017, 02:31 AM   #10
humfrz
Maybe you should have your hearing checked ??......
humfrz
Old 05-13-2017, 02:42 AM   #11
humfrz
Hi all,
I have a 2017 sport tech, and have noticed a rattle ............... Any advice on what I should do?
What I would suggest is that you load up a co-pilot, armed with a narrow, tape wrapped screwdriver, some foam and a can of silicone spray and go ah rattle hunting. Drive around and have the co-pilot push, pull, squeeze, nudge, pry, press, twist, on stuff until the rattle stops ...... then shoot it with spray or stuff some foam in there.
Back-in-the-day, with cars where you could get to stuff, we used these store bought, ribbed, rubber wedges to stop squeaks and rattles.
Good hunting!
humfrz
Old 05-13-2017, 08:08 AM   #12
BRZnut
Drives: BRZ DGM Limited
These cars all have rattles. Just when you find and fix one , another will appear.
Don't waste you time taking your car to the dealer unless you have time to waste and nothing else to do. Try to trouble shoot the cause yourself.
The dealer will not be able to fix the rattle and if they start tearing your dash apart they are likely going to make things worse.
Old 05-13-2017, 10:15 PM   #13
rkaywhodat
Drives: 2017 Toyota 86 Halo
Part of the experience.
Sent from my Nexus 6P using Tapatalk
rkaywhodat is offline   Reply With Quote
Old 05-13-2017, 10:16 PM   #14
Amatsukaze
Drives: Ultramarine FRS
Welcome to Toyubaru ownership. Embrace the rattle, become one with all the strange noises
Amatsukaze is offline   Reply With Quote
2017 interior lights / Diode Dynamics Var Cosmetic Modification (Interior/Exterior/Lighting) 7 04-03-2017 04:04 PM
Boost Festival 2017: Feb 25, 2017 Willow Springs GTA, JustDrift, Drift ModinJapan Southern California 1 01-25-2017 12:46 AM
[Video/Spanish] 2017 BRZ Complete Interior/Exterior Walkthrough ChaosBlades BRZ Photos, Videos, Wallpapers, Gallery Forum 4 08-27-2016 02:17 PM
Rattle noise car interior Mikeez Issues | Warranty | Recalls / TSB 13 09-27-2015 08:54 PM
Interior rattle frsinpa Issues | Warranty | Recalls / TSB 132 03-23-2015 04:09 PM
