Old 05-09-2017, 09:32 PM   #1
reynierpm
Drives: Toyota 86 2017 Black
If I change the stock receiver, can I use 3-Way speakers?
I am about to change the stock receiver for my Toyota 86 2017 for this one Sony XAV-AX100. I want to upgrade also the speakers on the front door to this one: Pioneer TS-A1376R (https://www.crutchfield.com/p_130TA1...l?tp=105&avf=Y).
When you add the speaker to your car there is a note saying: "The factory woofer in this location only receives bass frequencies from its amplifier. Replacement speakers will only reproduce bass" which makes me ask,
even changing the stock receiver I can't get 3 ways speaker working on the front door?
reynierpm is offline   Reply With Quote
Old 05-09-2017, 10:20 PM   #2
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
If you just "plug n play" using the common wire harness/adapter, then the sound from your new radio will not go to the door speakers until AFTER it has been sent to the small amp in the trunk that sends out ONLY bass.
You could run new speaker wires from the new head unit to the new door speakers, or bypass the stock amp. (Their could be impedance issues if you just bypass the amp, since the dash speakers are also in the mix...never measured so I'm not sure)
Twinz is offline   Reply With Quote
Old 05-09-2017, 10:21 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
Sounds about right. I think the stock sub amp is in the trunk behind the passenger seat.
##Edit: Yeah, what Twinz said.
Old 05-10-2017, 12:50 AM   #4
Chimera
Drives: FRS
just bypassing the stock amp is a bad idea. you can pretty easily replace it with a full range amp, which there is a thread on, but if you bypass it you will certainly cause an impedance issue.
edit:
those are 5 1/4 speakers. the door hole fits a 6.5 easily. you would want to select something from the 6.5 category.
Old 05-11-2017, 09:54 AM   #5
reynierpm
edit:
I am planning to replace the whole thing meaning amplifier, front door speakers and dash corner speakers but at Crutchfield they don't have anything that fits the car, could you point to the thread you mention here?
Old 05-11-2017, 10:19 AM   #6
Chimera
Drives: FRS
http://www.ft86club.com/forums/showthread.php?t=42239
I personally have a ktp 445u hooked up to spr-60c. it required running a wire from to door to the dash for the tweeters, but I like it. if you had a crossover block, which most 3 ways do, this wouldn't be necessary.
OEM amp harness to aftermarket 15A max amp >> amp to crossover blocks >> crossover block woofer output to oem amp output (this goes to the doors) >> crossover block mid and tweeter outputs run along the floor of the car and up the dash to the dash locations.
Old 05-25-2017, 07:30 AM   #7
reynierpm
Ok guys, I've spoken with Crutchfield and they told me they doesn't have anything that fits in my car. Any speakers and amps recommendation? The car stereo is installed now but is to much power for the stock speakers and amp and I don't like how it sounds, I am pretty sure it could sound better.
So you tell me what do you recommend
BTW, thanks in advance
FS: 2017 Stock speakers - All Drambeenie Audio/Visual, Electronics, Infotainment, NAV 1 03-15-2022 01:17 PM
FS: 2017 Stock speakers Drambeenie Interior Parts (Incl. Lighting) 0 05-04-2017 07:12 PM
WTB: Stock door speakers 86fanboy Canada Classifieds 2 03-01-2015 11:59 PM
WTB stock speakers BRZ/FRS WATCHMEHEAL Audio/Visual, Electronics, Infotainment, NAV 8 09-08-2013 11:40 AM
Are stock speakers Pioneer? newports Electronics | Audio | NAV | Infotainment 2 06-27-2013 02:02 PM
