Old 05-09-2017, 07:57 PM   #1
zoltiz
zoltiz's Avatar
Drives: '17 Toyota 86 6MT
Black badges for '17 86?
So apparently Toyota changed the badge size and the black badge kits don't fit the '17 86. I don't like chrome anywhere on the car, so it's a quest to find OEM-ish black badge set. Front is 4.5" wide, rear is 3.5" wide. Don't have part numbers for OEM badges yet - 2017s are not showing up in parts catalogs yet, so can't match it to other Toyotas to extend the search.
Anyone had any luck or am I the weirdo wanting to replace those?
'17 Halo 86 6MT
zoltiz is offline   Reply With Quote
The Following User Says Thank You to zoltiz For This Useful Post:
stevesnj (05-15-2017)
Old 05-09-2017, 08:43 PM   #2
Impureclient
Drives: 2015 FR-S
You're definitely a weirdo.
Impureclient is offline   Reply With Quote
Old 05-09-2017, 08:53 PM   #3
Chimera
Drives: FRS
Spray paint them. It's easy
Old 05-09-2017, 09:00 PM   #4
cat94
Drives: '17 86
http://www.ft86speedfactory.com/cata...ta+Emblems+-+2
cat94 is offline   Reply With Quote
Old 05-09-2017, 09:23 PM   #5
StraightOuttaCanadaEh
Wes
I used the Loden 86 emblem
Old 05-09-2017, 10:18 PM   #6
zoltiz
zoltiz's Avatar
Yeah, if the alternative is $70 or spraypaint, I might go for spraypaint.
'17 Halo 86 6MT
Old 05-13-2017, 06:23 AM   #7
Byza
Drives: 2017 86 GTS
Plastidip
Byza is offline   Reply With Quote
Old 05-14-2017, 11:42 PM   #8
cat94
Drives: '17 86
Originally Posted by Byza View Post
Plastidip
How many layers was this? And did the edges separate cleanly or did you have to do some cutting?
Tape in the middle is clever
Old 05-15-2017, 06:24 AM   #9
Byza
Drives: 2017 86 GTS
I did 3 coats, 15 mins between coats, 1 hour before peeling. Edges came away clean but I tried not to get a thick coat around the corners, mostly spraying top down with light coats from each side to make sure the chrome was covered.
I don't know if you care about the fender garnish but it required more coats, 5 I think, to get a nice coverage. The spray can was also getting pretty light so probably wasn't coating as thick. The edges pulled the first time (right side) but I lightly touched it up with a paint brush. The left side I removed the paper straight after the final coat while it was wet to prevent pulling. The inner parts (vents) I just shifted the paper inwards a bit so the edges moved away and then removed it completely once it was dry. I'll be doing it again after I get an opti-coat so I might do up a quick DIY next time.
The Following User Says Thank You to Byza For This Useful Post:
cat94 (05-15-2017)
Old 05-15-2017, 11:21 AM   #10
stevesnj
stevesnj's Avatar
Very nice, I hate chrome on this car too and painted my badges on my '16
My 2016 Build thread
Old 05-25-2017, 12:48 AM   #11
Borchert97
Borchert97's Avatar
Drives: 2017 Toyota 86
Seems like FT86SpeedFactory has updated 2017 badges now.
http://www.ft86speedfactory.com/exte...6/emblems.html
Borchert97 is offline   Reply With Quote
Black badges from the Hyper-Blue BRZ Kostamojen Cosmetic Modification (Interior/Exterior/Lighting) 14 06-23-2017 03:09 PM
OEM style badges, but black (not blue)? ixobelle Cosmetic Modification (Interior/Exterior/Lighting) 8 05-16-2017 05:20 PM
SCION BLACK BADGES odessitik Cosmetic Modification (Interior/Exterior/Lighting) 1 05-30-2015 03:41 AM
Black FR-S badges and emblems godon2894 Scion FR-S / Toyota 86 GT86 General Forum 18 10-26-2014 10:18 AM
matte black toyota badges Raven240 Cosmetic Modification (Interior/Exterior/Lighting) 8 07-31-2014 12:20 AM
