Old 05-05-2017, 11:30 PM   #1
Brz_racer
Drives: Subaru BRZ
Subaru BRZ premium fog lights
On the BRZ premium it does not come with fog lights, behind the trunk release button and dimmer there is a connector that has been taped off, is this the plug for the stock fogs on the limited model? I also looked in the cabin fuse box and I have the fuses installed for the fog lights, however the LED driver running lights on the premium do not have the pig tail connector that goes to the stock fogs. My question is to get a stock setup would you need the "limited" Driver running lights and a new turn signal stalk to get the fogs to work and have an indication on the instrument cluster that the fog lights are on?
Brz_racer is offline   Reply With Quote
Old 05-05-2017, 11:35 PM   #2
Presuming they are the same set up as the FRS ones yes the plug works. The switch isn't on the stalk on the FRS though. Are you sure it is on the BRZ?
Take a look here:
http://www.ft86club.com/forums/showthread.php?t=40153
Old 05-05-2017, 11:56 PM   #3
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Take a look here:
Weird! the BRZ fog switch IS on the stalk!
Old 05-06-2017, 12:04 AM   #4
Well I would guess that the connection would be the same so a FRS button set up should work. Be a pile easier than redoing a stalk.
Old 05-06-2017, 01:46 AM   #5
Brz_racer
Drives: Subaru BRZ
On the brz limited it is on the stalk, the premium has a different stalk and is missing the pigtail on the daytime running lights, ultimately I'm trying to figure out how to get the fog light indication light on the cluster to work without having to change the stalk. Anyone know what wire controls this indication?
Old 05-06-2017, 02:36 AM   #6
Read the FRS thread I linked. It makes the light work even though the stalk is not used. Many of the cars have the same wiring with the unused portions just taped up. Cheaper to put the wiring in all of them and build as needed then to pick what does and does not need it installed.
Old 05-06-2017, 02:49 AM   #7
Brz_racer
Drives: Subaru BRZ
Okay so I need that pigtail to the switch from the unused plug then
Old 05-06-2017, 05:40 PM   #8
Ragin Gti
Drives: '15 Subaru BRZ
https://techinfo.subaru.com/proxy/68...H4510CA000.PDF
Ragin Gti is offline   Reply With Quote
Old 05-06-2017, 06:59 PM   #9
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I bought the OEM fog light kit and installed it on my premium model. In the kit you will receive new daytime running lights and the fog light housing. There will be a round on and off switch you have to drill a hole into the trunk release, dimmer panel to install. It's all plug and play except for the 1 inch hole you have to make for the switch.
Trueweltall is offline   Reply With Quote
Old 05-06-2017, 07:54 PM   #10
gravitylover
Originally Posted by Trueweltall View Post
I bought the OEM fog light kit.. .
How much was that kit? I keep thinking I need to do that. The last few days we've had some serious fog and they sure would have been handy to have.
Old 05-06-2017, 08:53 PM   #11
g e
The fog lights on the BRZ (at least on my 2013 year) are useless.
My wife's 2005 Forester fog lights are far superior.
g e is offline   Reply With Quote
Old 05-07-2017, 12:40 AM   #12
Trueweltall
I paid around ~240?, I will have to check my email to give you the exact price. It was really easy to install, I didn't even have to remove the bumper or the wheels.
Old 05-07-2017, 03:55 AM   #13
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Sadly true. Just decoration. I replaced the bulbs with much brighter yellow LEDs from Diode Dynamics and I get a little more useful light for fog, but replacing the entire setup with real fog equipment is the only way to get real performance.
It's only money.
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 05-07-2017, 01:33 PM   #14
Poodles
Drives: 2015 Series.Blue
Yep, factory fogs are only 24w and not even visible that they're on from the drivers's seat. Only way you'd know they were on is the indicator on the dash.
TRS LED fog assembles fixed that for me...
BRZ fog lights on premium model b rawr z Cosmetic Modification (Interior/Exterior/Lighting) 22 02-08-2016 12:20 PM
Subaru Premium BRZ 86 & Premium Proud of Boxer Catalog & Broshure keioffice Miscellaneous 0 03-14-2014 08:10 AM
FT NJ: BRZ Limited OEM Fog Lights for Premium non-fog wawawoowee Exterior Parts (Aero, Lighting, Etc.) 10 02-02-2014 08:53 PM
Premium w/ fog lights? OakmanSmalls BRZ First-Gen (2012+) — General Topics 17 07-12-2013 10:14 PM
Fog Lights - Premium vs Limited Dionysus BRZ First-Gen (2012+) — General Topics 44 03-17-2012 03:15 AM
