Old 05-03-2017, 12:00 PM   #1
wparsons
wparsons's Avatar
Front camber, how much clearance does it gain/lose?
Looking at adding more front camber for this year, since it's daily driven year round I don't want camber plates (yummy salty Canadian winters) so I'll be adding more at the knuckle. I'm on stock diameter springs, so tire to spring perch clearance has been my reason for not adding more earlier. I'm going to add spacers up front to buy some clearance, but don't want to go thicker than needed (already have ARP studs, so no worries there).
I want room to add another full degree of camber, will 10mm be enough extra room? I don't currently have a ton of clearance, and am fine with ending up like that again.
flickr
Old 05-03-2017, 12:53 PM   #2
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
We have no idea what the rest of your setup is like. You can add a degree on a stock setup with loads of clearance. Best thing you can do is grab camber bolts, toss them in, and see how much an alignment shop can get out of them.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 05-03-2017, 02:00 PM   #3
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Depending on your width and offset, but I've gotten as much as -3* out front with 39et (45et with 6mm spacers) on 8" wide RPF1 with 245/40/17 tires with very minor rubbing. Do it. 10mm should be enough space.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
wparsons (05-04-2017)
Old 05-04-2017, 09:38 AM   #4
wparsons
wparsons's Avatar
The rest of the setup is irrelevant if you read the post. Doesn't matter how much camber I currently have, the amount of movement at the top of the wheel per degree of camber added at the knuckle will be relatively constant.
But since you asked, I'm currently at about -2.2* with maybe 2mm of clearance at the spring perch with 225/45 AD08R's on 17x8 +45 RPF1's. Already has camber bolts and slightly slotted upper strut holes, I'll be further slotting them to get more camber.
Cool, that's the kind of info I was hoping for! Ideally I want space to get up to ~ -3.2* with the current wheels and tires.
flickr
Old 05-04-2017, 10:18 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
wparsons: what bolts are you using in slotted holes? Also how much camber may eg. 1mm slotting bring? Did you also used something to prevent slipping?
The Following User Says Thank You to churchx For This Useful Post:
wparsons (05-11-2017)
Old 05-10-2017, 01:30 PM   #6
solidONE
solidONE's Avatar
Lets see some pics after you're done slotting. I recall with 2 sets of SPC bolts the upper/inner part of the knuckle was only a couple of mm away from the main shock body when maxed out. (just to give a rough idea how much you might have to slot the upper hole)
Intent > Content
Old 05-10-2017, 02:06 PM   #7
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Will, my Raceseng CasCam plates look wonderful after 3 years of Canadian winters. With the exchange the way it is, it would be an expensive solution but easy to align!
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Old 05-11-2017, 10:48 AM   #8
wparsons
wparsons's Avatar
Whiteline lobed bolts (same as SPC).
They've been slotted slightly for years, I'm just looking at slotting further. Currently I have like 2mm of clearance between the tire and spring perch, hard to get a picture in there though. My question wasn't about how much to slot, but if a 10mm spacer would be enough clearance for 1* more camber.
That's good feedback Drew... might have to reconsider them.
flickr
Old 05-11-2017, 11:04 AM   #9
OND
OND's Avatar
Drives: 2023 BRZ
I remember going from 1.3 to 2.3 camber on stock suspension and the clearance loss was about "half finger", so around 5-6mm??
This is also verified by a very crude 608/2*sin(1) sort of calculation, which gives 5.3mm, so I'd say 10mm spacer should have you covered.
OND is offline   Reply With Quote
The Following User Says Thank You to OND For This Useful Post:
Old 05-11-2017, 01:25 PM   #10
solidONE
solidONE's Avatar
I'm just curious how much you have to slot to get 3.2. I have a set of stock dampers of a 15 I'm considering doing the same to.
Intent > Content
Old 05-11-2017, 07:26 PM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
I'd love to get just by slotting upper hole some -2* + some insert/spacer in slot to prevent bolt slipping + use normal non lobed full strength bolt there.
And normal cambolt in lower hole, so i can get adjustment in -1/-3 range.
For now just gathering info on slotting (eg. how much slotting needed).
Also asked suspension shop to inquire Ohlins, what dimensions are for their Ohlins TTX rally strut slot inserts, as they look like something that will do what i wanted in first sentence. P/N: O-5794-00 (3.0mm), O-5794-01 (2.44), O-5794-02 (1.88), O-5794-03 (1.32), O-5794-04 (0.76), O-5794-05 (0.20mm offset).
Old 05-11-2017, 10:12 PM   #12
wparsons
wparsons's Avatar
I'm actually looking for a low km set of new shocks as well, so I'll likely be re-slotting them if I can find anything and slotting enough to run the stock upper bolts.
In any case, I'll measure how wide the holes end up being and let you know.
flickr
Top hat camber to clear front inner fender clearance switchlanez Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 11-22-2016 03:02 PM
How much power to gain/lose? Timmy_Jones Engine, Exhaust, Transmission 40 04-08-2016 05:42 PM
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
