Southern California SoCal
Old 04-19-2017, 02:26 AM   #1
ry_zillafrs
ry_zillafrs's Avatar
Drives: 2013 FRS - Ultramarine
REMOVING 3m tape from car
So i used 3m double sided tape to install my spoiler on my frs. and now i want to take it off becuase im going back to the stock look. any suggestions on how to do this without messing up the paint?
2013 ULTRAMARINE FR-S
ry_zillafrs is offline   Reply With Quote
Old 04-19-2017, 03:25 AM   #2
shaynek
shaynek's Avatar
Drives: BRZ Limited; GR86
use a heat gun to heat up the tape. then you should be able to remove the spoiler and the tape residue
shaynek is offline   Reply With Quote
Old 04-19-2017, 04:12 AM   #3
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
Leave it out in the sun, get some fishing line and saw away. helps to have an extra hand to help lift the spoiler. then lots of goo gone to clean up. good luck
Old 04-19-2017, 04:23 AM   #4
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Lots of goo gone and time.
Decimus is offline   Reply With Quote
Old 04-19-2017, 06:33 AM   #5
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Goo Gone is fine, Don't confuse it with Goof Off! Goof Off will eat the paint very quickly.
Old 04-19-2017, 03:00 PM   #6
Pekingduck
Drives: 4 wheels
I use heat and whatever left use this
https://www.amazon.com/3M-03618-Adhe.../dp/B000BQYA7W
Pekingduck is offline   Reply With Quote
Old 04-19-2017, 05:15 PM   #7
MuseChaser
Feeling like thinking....
MuseChaser's Avatar
You'd be amazed at how good WD40 is at cleaning off adhesive residue of any kind. As a lubricant, it's awful... as a cleaner, it rules.
Drive like everyone's life around you depends on it...
MuseChaser is offline   Reply With Quote
Old 04-19-2017, 06:00 PM   #8
Chronology
Drives: 13' Satin White Pearl BRZ
This man buys WD40 in bulk. It won't ruin your paint, you can let it sit a bit and give it some elbow grease.
1. Heat the area
2. Use fishing line as a knife to remove what you can
3. Soak in WD40
4. Get your Friday night rub on
5. Clean area with water + detail spray of your choice and you should be good to go.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 04-20-2017, 01:48 AM   #9
ry_zillafrs
thanks everyone!!!!!!!!!!!!!!
Old 04-20-2017, 11:37 PM   #10
bryanttttttta
Drives:
Try rubbing alcohol. Works for tape adhesive.
Co-Founder of SlideFactoryInc Grip/Drift Events
www.slidefactory.org
bryanttttttta is offline   Reply With Quote
Trakk Tape Black Tire Tracking / Autocross / HPDE / Drifting 10 05-15-2017 05:03 PM
3M tape for TRD JP parts? MisterSheep Cosmetic Modification (Interior/Exterior/Lighting) 8 02-25-2017 10:36 PM
Is that...grip tape? Firejetmanguy Scion FR-S / Toyota 86 GT86 General Forum 56 04-13-2015 05:18 PM
3M Tape ThatManAnt Cosmetic Modification (Interior/Exterior/Lighting) 7 07-18-2014 07:28 PM
which 3m tape is this? mokinbird87 Cosmetic Modification (Interior/Exterior/Lighting) 8 08-29-2013 09:12 PM
