Old 04-17-2017, 02:28 PM   #1
rokius
rokius's Avatar
Drives: '13 Whiteout FR-S
Series 10/Monogram headlight install
Anyone in DFW willing to help me install Series 10 headlights into my '13 base FRS? These have the 6 pins in the 8 pin connector. I'll be getting the headlights soon and I'm not too comfortable with electrical wiring. I've read thoroughly​ through numerous threads but just don't want to screw up my expensive OEM headlights.
In the end, I'd like them to function like factory - LEDs off when low beam or high beam is on. Only functioning as DRL or when parking lights are on. I'll pay of course!
Thanks!
Sent from my Nexus 6P using Tapatalk
rokius is offline   Reply With Quote
Old 04-26-2017, 11:52 AM   #2
NickDC88
NickDC88's Avatar
I did GT86 headlights in my '13 a couple of weeks ago. Pretty simple if you follow the write-up. I've heard the Monogram lights are even easier because there isn't the extra wire. Just take it slow, triple check your work and you'll be fine.
NickDC88 is offline   Reply With Quote
Old 05-01-2017, 05:43 PM   #3
rokius
rokius's Avatar
Yeah just finished mine a week or so ago. Not too bad. I even have a pin diagram with colors if anyone else needs it in the future.
The Following User Says Thank You to rokius For This Useful Post:
NickDC88 (05-01-2017)
Old 05-01-2017, 07:11 PM   #4
NickDC88
NickDC88's Avatar
Did you get them to work the way you wanted them to?
Old 05-02-2017, 08:34 PM   #5
rokius
rokius's Avatar
Yeah. LED off when lowbeams and highbeams are on. Only enabled with car on, and parking brake disengaged. I had to reference some Scion wiring diagrams and create my own diagram that I could understand. One model with the stock 6pin FRS pin layout and one with the Monogram 8pin layout with wire colors. Install was easy after that lol.
Old 05-11-2017, 08:37 PM   #6
rokius
rokius's Avatar
To anyone who wants to see my diagram, please check this out. https://drive.google.com/file/d/0Byp...1GY3hNTkE/view
The Following 3 Users Say Thank You to rokius For This Useful Post:
C3 (05-19-2017), Jyn (06-07-2017), try2findmark (06-26-2017)
Old 03-16-2018, 12:33 AM   #7
mikeyvaj
Drives:
What about the resistor box? I'm looking into it but don't know what to do with it.
Sent from my SM-N950U using Tapatalk
mikeyvaj is offline   Reply With Quote
Old 03-16-2018, 08:45 AM   #8
rokius
rokius's Avatar
Resistor box gets unplugged. I unclipped mine from the car too, in case a shop decided to plug it back in.
Sent from my ONEPLUS A5000 using Tapatalk
Old 03-16-2018, 08:54 AM   #9
mikeyvaj
Drives:
Where do I re wire the new wire? I know the base got 2 plugs vs the monogram series
Old 03-16-2018, 08:59 AM   #10
rokius
rokius's Avatar
It's 6 pins from the monogram (6/8 used) to 6 pins on base FRS. There is no new wire, other than extending the wires from each headlight that tap into the green resistor wire.
Old 03-16-2018, 09:17 AM   #11
mikeyvaj
Drives:
That's what I needed to know. I gotta your diagram so I think ill be set. Thanks rokius.
wtb headlight for monogram or release serie snowman Canada Classifieds 2 01-03-2016 08:29 AM
FS: DRL Mod for Monogram/10-Series/Release Series 1.0 leoh007 Exterior Parts (Aero, Lighting, Etc.) 0 05-12-2015 12:15 PM
FS: DRL Mod for Monogram/10-Series/Release Series 1.0 leoh007 Audio/Visual, Electronics, Infotainment, NAV 0 05-12-2015 12:14 PM
BRZ headlight swap to Monogram Series *UPDATE:10/12/14 w/ Pics* JDis3 Cosmetic Modification (Interior/Exterior/Lighting) 31 04-12-2015 05:31 PM
Monogram headlight issues Simon Cosmetic Modification (Interior/Exterior/Lighting) 8 10-28-2014 10:48 AM
