Old 07-16-2012, 01:16 AM   #1
RZ86
RZ86's Avatar
Drives: 2012 Toyota GT 86 Manual
Tail Light Cracks + Condensation
Hey guys!
So I've noticed a few cracks in my tail lights. I took the red vinyl off my tail lights to find cracks on both tail lights in the same location (yet, different types of cracks).
Toyota has been over to check the lights, take photos, etc, but I have a feeling they're going to try the whole "you voided your warranty by putting vinyls on the tails", which would be a whole lot of crap. The vinyl went on with ease, and was defiantly NOT the cause of the cracks.
I have also noticed some condensation from time to time (especially after it's been raining and it's cold).
Toyota better replace these under warranty. I have done some reading on the US forums and apparently a few people are having the same issue (cracks from weather temp from hot to cold). I'll defiantly take it further if they decline my warranty claim. I have done nothing but be honest and careful with my 86. If I do mod the car, and a part breaks due to that modification, I would happily take responsibility for the breakage.
I will keep this thread updated with the progress.
Fingers crossed Toyota do the right thing and just replace them.
few pics:
Current: '12 Toyota GT 86 Pearl White Manual
Previous: '96 Toyota Supra SZ-R
RZ86 is offline   Reply With Quote
Old 07-16-2012, 01:58 AM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
You're probably not going to want to hear this but vinyl wraps and overlays have been known to cause cracks in some lights due to heat expansion and contraction (which is exacerbated by the overlays from my understanding)...however, this has been a source of controversy on many car forums for years
Old 07-16-2012, 02:02 AM   #3
mashal
DADA
mashal's Avatar
Drives: 2013
That .
Pfft
mashal is offline   Reply With Quote
Old 07-16-2012, 02:15 AM   #4
RZ86
RZ86's Avatar
When we installed the vinyls, we didn't stretch them much. There were 3 pieces to each tail light, so I'm not sure if this is the reason for the cracks.
Old 07-16-2012, 10:25 PM   #5
KAB-FRS
KAB-FRS's Avatar
Drives: 2013 Scion FRS/whiteout,MT
On our other blue FR-S we have the same problem with the tailights, they even have a puddle of water inside.
KAB-FRS is offline   Reply With Quote
Old 07-17-2012, 07:14 PM   #6
Chillz
Drives: Asphalt FR-S & S14
Maybe it's not about how you installed the vinyl but more about how you installed the tail lights. Check this post. Are there cracks on the back side of your tail lights as well? If the tail lights weren't seated properly when you reinstalled them, cracks could have developed in the housing back side. Maybe they were seated incorrectly and the bolts were tightened so much that it cracked the front as well?
Originally Posted by Moto-P View Post
Ok guys, problem solved at the assembly line, according to CE. And here's what to do if you have mild condensation.
There seems to have been some tail-lamp assembly not fully seated in the body bezel and screwed into place, causing tiny crack in the housing back side on rare cases.
To inspect, just loosen the tail-lamp housing nuts, and see if there are any cracks. If not just screw it back in, and your car should be perfectly fine.
In the meantime, it will not affect the performance of the tail lamps in any way, and if the problem develops in rare cases afterwards, it is under warranty. This should not be a common issue they say, and is covered under normal warranty.
Again, you MUST love Toyota for getting right up and quick to fix any issues.
From: http://www.ft86club.com/forums/showp...9&postcount=62
Chillz is offline   Reply With Quote
Old 07-18-2012, 04:35 AM   #7
RZ86
RZ86's Avatar
We never took the tail lights off the car. Just wrapped them while they were on the car.
Old 07-18-2012, 05:18 AM   #8
FT-86GOD
Senior Rocket Bunny
FT-86GOD's Avatar
Drives: 1982 XX KE70
Just out of curiosity why did u tell toyota u had put vinyl on them anyway?.
BOSOZOKU STYLE BITCH........
FT-86GOD is offline   Reply With Quote
Old 07-18-2012, 05:27 AM   #9
os86
Drives: 2jz
^^ They spotted it when went in for 1k service I think
os86 is offline   Reply With Quote
Old 07-18-2012, 05:33 AM   #10
20valvewynn83
20valvewynn83's Avatar
Drives: 2013 FRS/01 Tacoma
As a Toyota Tech i will tell you if this car came into the shop with this issue i would just order the rear tail light even if it had vinyl on it when it came in. Well i have been out of work due to a back problem that happen well working, some of my friends have already told me about this issue so you would not be the only one with this problem. Toyota is looking into this and a few people have already had the rear tail lights replaced due to this.
20valvewynn83 is offline   Reply With Quote
Old 07-18-2012, 07:55 AM   #11
RZ86
RZ86's Avatar
I really hope Toyota just do the right thing and replace these tails. Obviously there was a factory fault.
Old 07-18-2012, 11:46 AM   #12
Chillz
Hopefully they replace them for you. And hopefully the replacement tail lights are better/stronger and not just a new unit with the same weaknesses.
Old 07-18-2012, 12:17 PM   #13
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
Im thinking it will be the exact same part until FRS/BRZ V2.0 come out for 2014. At which time anyone still having the issue can still replace the taillights. Just take them in every spring and fall with the cracks being cause by the temp change for your brand new tail lights!
RandomHero is offline   Reply With Quote
Old 07-18-2012, 01:07 PM   #14
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Wow, I never knew that. Maybe it wouldn't be a good idea to wrap them, especially on this car that has a weak plastic cover.
Tail Light Condensation rbrtndrws Issues | Warranty | Recalls / TSB 1033 04-16-2019 10:57 AM
tail light Sketch575 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 07-11-2012 02:32 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 04:43 PM
Condensation in Tail light? Subaruwrxfan BRZ First-Gen (2012+) — General Topics 4 06-08-2012 04:14 PM
Tail Light condensation Genomaxter Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-01-2012 03:45 PM
