Old 04-15-2017, 11:40 AM   #1
Riftur
Riftur's Avatar
Having Tires mounted on expensive wheels
I am finding it hard to locate a tire shop to install my new rims on my car. They all want me to sign something that states they are not responsible if anything happens to the rim during the install. I live in the Fort Lauderdale, FL area. Is this normal? If not is there anyone who knows of a place I should go to in this area?
Riftur is offline   Reply With Quote
Old 04-15-2017, 04:17 PM   #2
Gunman
Drives: 2019 Mazda Miata RF
I'd ask the guys at a custom shop who they use, like Mad Mods over on Dixie http://madmods.com/
Gunman is offline   Reply With Quote
The Following User Says Thank You to Gunman For This Useful Post:
Riftur (04-16-2017)
Old 04-15-2017, 05:21 PM   #3
humfrz
First you let the air out of the tires ...... then you run over the edge of the tires with a tractor (to break the bead) ...... then you get two crow bars ........
humfrz
finch1750 (04-15-2017)
Old 04-15-2017, 06:01 PM   #4
mrg666
pessimistic skeptic
mrg666's Avatar
I try no to go to Firestone, Midas, Pepboys, etc. Instead I try to find a local shop that has an "owner" in store and employs real technicians that know what they do instead of a couple of drifters that change every couple of months. But be ready to pay two times more. Otherwise, for half the price, sign the paper and pray.
The Following User Says Thank You to mrg666 For This Useful Post:
strat61caster (04-16-2017)
Old 04-15-2017, 06:16 PM   #5
kn0x47
Drives: '13 raven 6spd
exclusive motoring is down in maimi if you're willing to drive a bit. Also search for wheel repair shops in your area. My local wheel repair shop has a touchless tire mounting machine
kn0x47 is offline   Reply With Quote
The Following 2 Users Say Thank You to kn0x47 For This Useful Post:
Riftur (04-16-2017), why? (04-18-2017)
Old 04-15-2017, 08:18 PM   #6
dhuang
Cannonball Record Guy
dhuang's Avatar
Drives: Series.Yellow, 4C, Fit
Most Discount Tires should have a Hunter or equivalent touch-less machine. Make sure you bring it up with them that the wheels are in perfect condition prior to install, and that you are accepting a liability by having them mount them. I had them buy me a new wheel when I found a dismounting indention on the lip.
Most DT's are pretty friendly and understanding imo. They usually use the touch-less on the really expensive wheels to minimize human error -- the machine just takes way too long compared to a normal tire tech.
dhuang is offline   Reply With Quote
The Following 2 Users Say Thank You to dhuang For This Useful Post:
Alltezza (04-16-2017), Riftur (04-16-2017)
Old 04-15-2017, 10:16 PM   #7
DarkSunrise
DarkSunrise's Avatar
If you're really worried, take them to a wheel repair shop. If anyone can mount/dismount tires without damaging the wheels, it'll be them.
2022 BRZ Build
2013 FR-S Build
Old 04-15-2017, 10:37 PM   #8
Teseo
Drives: frs
Ask about install them from the back/behind
Old 04-15-2017, 10:39 PM   #9
arxm
Drives: 2013 FR-S, 2023 BRZ
wouldn't it be hard for them to do that as they would have to somehow clamp the rim down on the face?
2013 Whiteout FRS 6MT with a JRSC @ 330ish WHP on E98
2023 Ignition Red BRZ 6MT awaiting boost
arxm is offline   Reply With Quote
Old 04-15-2017, 10:55 PM   #10
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
I'm a former tire technician. I was pretty good at my job. Accidents happen though. Luckily the owner of the shop I worked at provides the best service you could possibly get.
We damaged your wheel? Not only are we fixing it, but now we're not charging you for mount and balance. We had a "touchless" machine. But you wouldn't believe the tension some wheel and tire combos give you.
Anyways, I'd be running away if they wanted me to sign a waiver form.
And for the record, a reverse mount is likely to cause more damage to the wheel if the tech already doesn't know what they're doing. And you can't (well I'm sure some people manage...) reverse mount a tire onto a wheel unless the wheel is designed that way.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
The Following User Says Thank You to HeadBanger For This Useful Post:
mr_squirrel (04-16-2017)
Old 04-16-2017, 07:21 AM   #11
Riftur
Riftur's Avatar
very few and far between. I wish i could still find those shops.
Old 04-16-2017, 07:25 AM   #12
Riftur
Riftur's Avatar
I have been. I though of wheel repair shops but the place needs to sell me tires also. I can not transport tires and rims in the car.
Old 04-16-2017, 07:43 AM   #13
HeadBanger
HeadBanger's Avatar
Why not? There's so much room in these cars!I've have 6 mounted wheels in the car before.
Old 04-16-2017, 08:07 AM   #14
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
This, my local Discount Tire shop has been nothing but great to me. If you have one in your area I'd give them a call and tell them about your wheels, they're usually always excited to see some nice wheels compared to the normal OEM wheels that they always work with everyday
Alltezza is offline   Reply With Quote
WTB: 5x100 Wheels with tires mounted- $1600 budget Tsuin Want-To-Buy Requests 7 07-09-2015 09:30 AM
getting tires mounted on stock rims? ハチロク Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 11-25-2014 08:09 PM
Expensive light Rims+Expensive light Tires or Suspension+Cheaper Rims+Cheaper Tires? OnionTou Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 08-09-2013 06:57 PM
Why are ISS wheels so expensive? EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 02-05-2013 04:36 AM
Stock Tires mounted? feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-19-2012 04:02 PM
