Old 04-13-2017, 11:58 PM   #1
-Willis-86touge
Drives: Stock
Can you post pick of oft mounts?
So just got my oft been trying to figure out how to mount it and where? Any pictures of anybody's? Or maybe there's a thread already?
-Willis-86touge is offline   Reply With Quote
Old 04-14-2017, 03:02 AM   #2
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
Recommend buying a extension OBD cord can enable you mount anywhere in your car.
FR-Sky is offline   Reply With Quote
The Following User Says Thank You to FR-Sky For This Useful Post:
-Willis-86touge (04-14-2017)
Old 04-14-2017, 03:21 AM   #3
e_lunatic
Drives: 2015 Scion FR-S
http://www.ft86club.com/forums/showthread.php?t=64634
e_lunatic is offline   Reply With Quote
The Following User Says Thank You to e_lunatic For This Useful Post:
Old 04-14-2017, 08:56 AM   #4
Teseo
Drives: frs
CD mount. No cable extension required
The Following User Says Thank You to Teseo For This Useful Post:
Old 04-14-2017, 09:57 AM   #5
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
I have the Scosche Magic Mount. Works great, no extension required either.
Edit: Just realized the picture on the left is of my old mount, which ended up breaking. The magic mount is on the right. Same location used for mounting. The magic mount works a let better. Very strong magnet.
golfyankee2121 is offline   Reply With Quote
The Following User Says Thank You to golfyankee2121 For This Useful Post:
Old 04-14-2017, 09:56 PM   #6
BFIFE22
BFIFE22's Avatar
Drives: 2013 GBS BRZ Limited
I used a Scosche air vent mount. It's magnetic so you put the flat magnet piece on the back of the OFT and voila
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
BFIFE22 is offline   Reply With Quote
The Following User Says Thank You to BFIFE22 For This Useful Post:
-Willis-86touge (04-15-2017)
Old 04-15-2017, 06:45 PM   #7
-Willis-86touge
Drives: Stock
So mounted mine with the scosche stick and mount.
Old 04-15-2017, 06:47 PM   #8
-Willis-86touge
Drives: Stock
I do have a another question? Someone said to get the cord with the power off option? My oft turns off with the car! Is this not good enough? Seems to me if it's off then it's not drawing any power?
Old 04-16-2017, 09:34 AM   #9
Riftur
Riftur's Avatar
I have same setup as you
Riftur is offline   Reply With Quote
Old 04-16-2017, 04:03 PM   #10
golfyankee2121
It still draws a little bit of power off the battery, and if left for a long period of time, can cause your battery to die. I just unplug/plug in my OFT every time I get in/out of the car, unless I know I'm going to be quick. But I always unplug it and store it in the glove box while I am at work, or overnight, etc.
-J.B.
-Willis-86touge (04-16-2017)
FS: Cusco Engine Mounts, Brand New mrk1 Engine, Exhaust, Bolt-Ons 13 10-10-2017 04:23 AM
FS:(NJ) OEM LCA $50 pick up zc06_kisstherain Brakes, Suspension, Chassis 11 05-19-2017 02:15 PM
alright my tenth post so i can officaly post in the marketplace destiny86 Scion FR-S / Toyota 86 GT86 General Forum 4 02-04-2016 12:49 PM
If you were to pick a used "High end" Sports car what would you pick? Atropine Other Vehicles & General Automotive Discussions 133 08-02-2014 02:00 AM
Window weld motor mounts (poor man's solid mounts) unsurety Engine, Exhaust, Transmission 8 06-05-2014 02:36 AM
