Old 04-11-2017, 01:40 AM   #1
jpeaslee
Drives: 02 Toyota 4Runner
OFT Which tune/bin?
I'm sure this info is out there, but for the life of me I can't seem to find it (I know it's gotta be somewhere obvious, but I'm not seeing it).
Within the folders of different tunes (specifically Stage 2, EL, E85), there are a lot of different BIN files. What's the difference between them?
jpeaslee is offline   Reply With Quote
Old 04-11-2017, 10:48 AM   #2
Chimera
Drives: FRS
they correspond to the ecu revision/region/year
like NA 2013 is B01C
when you plug the OFT into the car and read the ECU, it should show you your revision on the screen, should also show you in Open Flash Manager somewhere. I would get a screen shot but mines currently at home, and I am not, but should be pretty easy to figureout. I think its on the main screen what your revision is, just use the bins out of the revision.
and in case your wondering why it matters, the tables values go to different memory locations on different revisions I believe, so if you use a rom from the wrong revision you might write to the wrong places which can lead to overwriting critical code, bricked, ECUs, and other bad things.
Long story short be careful to use the revision that matches your car.
if your still unsure post some screenshots of open flash manager with your oft plugged in and I'm pretty sure someone here can help you.
Old 04-19-2017, 09:57 AM   #3
Tomita San
Tomita San's Avatar
Drives: Scion FR-S
Just wanted to update my UEL Stg2 tune with the most recent one (after 2 years). When i connect the tablet it shows the cal ID ZA1JA00C, but when i select "Tune" and then -Info it shows ZA1JB01C.
What ID tune should i use now?
Tomita San is offline   Reply With Quote
Old 04-19-2017, 10:30 AM   #4
steve99
The oft wont let you load wrong calibration ID.
Your original rom was A00C, and the OFT has effectively updated yo to B01C roms.
But you still load A00C oft tunes
Tomita San (04-19-2017)
OpenFlash Headers in 2017 &a Tune -- success & no tune yet gskv Software Tuning 151 03-29-2018 08:10 PM
B01D 6AT SBD Turbo Tune Questions *Tune Attached* Pro60modman Software Tuning 6 09-05-2016 09:04 PM
How can you trust a tune? (tune noob) Benschneider06 Software Tuning 20 05-21-2015 11:03 AM
Drift Office Tune vs Visconti Tune mechaghost Engine, Exhaust, Transmission 109 07-03-2014 12:57 AM
difference between vortech tune and perrin tune? Frs32907 Forced Induction 7 12-05-2013 02:49 PM
