Old 04-10-2017, 01:28 AM   #1
Drool Monkey Mech
Drives: Lowered, metallic blue paint
Engine Swap for 2015 FRS
So my co-worker drives an automatic FRS and wants to do an engine swap. He knows next to nothing about cars or how to replace/install new parts. I told him I would help him do an engine swap if that is what he wanted to do. I have replaced my engine on my Celica and plan to do a whole new build for it soon. He told me he wanted to drop in a 2JZ, but after I told him we would not be able to just plug and play that engine he kind of backed off that idea. I was wondering what engine would be a great swap for not having to do any frame modifications? I'm looking at a few possibilities right now, but not knowing much about the FRS, I'm kind of stuck trying to find something that could work. I plan to rip out his automatic tranny and replace it with a manual tranny. Any suggestions?
Drool Monkey Mech is offline   Reply With Quote
Old 04-10-2017, 08:34 AM   #2
Calum
That Guy
Drives: 2013 asphalt FRS MT
I think a B16 swap would be perfect for you guys.
Old 04-10-2017, 08:42 AM   #3
MRS-Colin
Drives: 2001 Impreza 2.5 RS
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 04-10-2017, 08:45 AM   #4
Cole
Not a troll
Cole's Avatar
Hahahahahahahahahahahahahahahahaha
What are your goals? What are your budgets? What are your skill levels?
For what it's worth, @Pure Automotive does in fact have a plug and play wiring harness (that is $6k), and, I believe just about everything else you'd need to drop a 2JZ into the FRS, failing that, plenty of other vendors make mounts and baubles that will make it work. Here's the thread
Maybe your friend needs someone new to take advice from?
Old 04-10-2017, 08:50 AM   #5
Calum
That Guy
Originally Posted by MRS-Colin View Post
I'm laughing way too hard that this.
Old 04-10-2017, 10:22 AM   #6
Drool Monkey Mech
I will have to show him a B16 and see what he thinks about it thanks.
I do not think he wants to pay more than maybe 5k for an engine swap. He is being kind of cheap with this swap, which I told him already he should be looking to drop about $5k to $6k easy. His goal is to get a better engine in there then what he has now. He wants something a bit faster. My skill levels is being able to replace an engine, rebuild one if need be, pretty much any work I need to do on a car I can, expect weld. I have not welded anything in about seven years or so, and would not want to start again with welding on a car. My co-worker though he was barely able to manage a direct fit exhaust swap.
Old 04-10-2017, 12:50 PM   #7
strat61caster
strat61caster's Avatar
This is the only thing that makes this believable and the most intelligent thing in your posts.
Any engine swap that's cheap will fail smog checks in counties that do them and the car will not be street legal. In two-three years depending on when he bought the car it will fail emissions unless the swap meets the requirements and he will be facing a significant fine along with a car that's no longer street legal.
Given budget, needs, your claimed capability & knowledge, and location, get a smog legal supercharger kit. ~50% power increase, reliable, plug and play in a weekend, street legal.
http://www.edelbrock.com/automotive/...ers/fa20.shtml
http://jacksonracing.com/jackson-rac...stem-released/
ineedyourdiddly
Old 04-10-2017, 05:55 PM   #8
Drool Monkey Mech
That is what I was recommending to him today. I think if he does not want the body or frame modified he would be better going with a turbo or like you said a supercharger kit. The area he lives in does smog checks so yea it would most likely fail smog unless he wanted to spend the extra cash for it. It honestly sounds like he might want to back out of this project after I told him more of what I have been reading up on his car.
Old 04-10-2017, 07:37 PM   #9
DrifterD
Drives: 15' Halo
Whats his reason for wanting to swap the engine when he doesn't know anything? Seems odd to me. I know people complain about its power but 5-6k wont cut it for a swap that will give him more power. Hes better off boosting the FA20 as others have recommended already.
2015 Halo MT
@denneee
@haroseattle
DrifterD is offline   Reply With Quote
Old 04-10-2017, 11:57 PM   #10
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
If you genuinely believe what you're saying, then I would also suggest looking into a 1NZ swap.
What Strat said. It seems like this would be a much easier task for you and your friend to perform.
If your friend is looking for bigger power beyond what the CARB kits can provide and given his lack of knowledge, he may just be better off trading up to a more powerful car altogether.
Old 04-11-2017, 07:35 AM   #11
Calum
That Guy
Originally Posted by Wikipedia
The 1NZ-FE is a 1.5 L (1497 cc) conventional Otto-cycle variant of the 1NZ-FXE with VVT-i. The engine block is found in many Toyota models assembled in Japan and Asian countries. It retains the same bore and stroke, but the compression ratio is lowered to 10.5:1. Output is 81.2 kW (109 hp) at 6000 rpm with 141 Nm (103 lb·ft) of torque at 4200 rpm. The redline is 6400 rpm.
Perfect
Old 04-11-2017, 08:47 AM   #12
kevman_101
Drives: 2013 Scion FRS
Swap for an FA20. It`s direct bolt on, wiring and even the ECU is compatible.
kevman_101 is offline   Reply With Quote
Old 04-11-2017, 12:25 PM   #13
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Move on to the FI section and even then, $6k may be barely enough.
Sent from my ONEPLUS A3000 using Tapatalk
Old 04-21-2017, 10:14 PM   #14
Ericlobster
Drives: blue
Yup
I agree. B16 all the way. Especially if you can do it yourself (timing belt, water pump, clutch the whole works).
@Calum - Funny nonetheless
Ericlobster is offline   Reply With Quote
2JZ engine swap? s_king20 Engine Swaps 8 12-10-2015 03:09 PM
2015 wrx hub swap/info? manonastick Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-02-2014 04:13 PM
Engine swap JDM EJ25 STI engine FRSToyota86 Engine Swaps 25 11-20-2013 01:56 AM
4-AGE engine swap on FR-S bacon_cheese_beer Scion FR-S / Toyota 86 GT86 General Forum 31 12-16-2012 02:23 PM
Engine Swap cf6mech Engine Swaps 21 11-16-2012 02:52 AM
