Old 04-08-2017, 10:25 PM   #1
Roneezy
Roneezy's Avatar
Drives: Scion FRS Halo White 2015
Advice please, from those who had problems...
Hello,
I have a 2015 FRS Automatic that has 28k miles on it and purchased it July 2015.
So this past Wednesday April 5th I started up my car to leave work and as I was leaving the parking garage my traction control and CEL came on. Drove straight to dealership and was told it was something of a camshaft sensor.
Something like that(not exact words). Then they cleared the code and drove it for a few miles, now a new code popped up.
This time my Fuel Pump Assembly.
They'll let me know on Monday what step they'll take next...
I fear that this is the start to a series of headaches. I know this is still covered under warranty and what not, but has anyone else gone through this?
What should I do next? Service adviser also said that with my car being lowered and having aftermarket wheels, if a Toyota rep came I'll most likely be voided for any major repairs...
Only mods I have are
Bilstein shocks and Eibach Lowering Springs
MXP Comp RS Catback Exhaust
Ambit Wheels/Super Sport Tires
Delicious Tuning flash and go stage 1
K/N Drop in Air Filter
Are they able to discover that I tuned the car? Thats really the only engine mod I have going on with it.
Roneezy is offline   Reply With Quote
Old 04-08-2017, 10:32 PM   #2
rkaywhodat
Drives: 2017 Toyota 86 Halo
Everything I have ever read about tunes from the tune manufacturers say if someone who knows what to look for will find it.
Sent from my Nexus 6P using Tapatalk
rkaywhodat is offline   Reply With Quote
Old 04-08-2017, 10:39 PM   #3
Roneezy
Roneezy's Avatar
That's what I was thinking... Damn man I don't want to be denied warranty repairs
Old 04-08-2017, 11:20 PM   #4
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
My cust. service rep told me warranty would only be denied if the aftermarket part is the cause of problem. He also said catback exhaust wouldn't deny warranty because it's bolted on. I can't remember the name of that aftermarket thingy that protects the consumer. Sorry I got a brain fart moment.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 04-08-2017, 11:33 PM   #5
Zhangy
Drives: 2015 FRS
the flash bro..
Zhangy is offline   Reply With Quote
Old 04-09-2017, 06:20 AM   #6
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
You're thinking of the Magnusson-Moss act.
No way wheels or a lowering kit can affect engine issues.
But that flash... OP is likely screwed.
Shinigami301 is offline   Reply With Quote
Old 04-09-2017, 07:30 AM   #7
Lantana frs
Drives: 13 frs red
The tune will probably be an issue when they try to reflash and the ecutek locks them out.
Lantana frs is offline   Reply With Quote
Old 04-09-2017, 08:20 AM   #8
Riftur
Riftur's Avatar
I have a 2013 AT with 27k on it. I am getting the codes P0011 and P000a. They are both camshaft related. I got the error code for the first time at around 23k miles but it didnt trip the CEL light. I only know about it because I run the Torque app and it monitors for codes. I cleared it and everything was fine for a few months then it came back again. It seems to happen every couple weeks when I put the car in sport mode and drive it hard. About 1 month ago it did trip my CEL light but it hasnt happened again. I have an appointment with the dealer next week. From what I have read they have a long list of stuff to keep changing until they finally change the ECU which usually fixes it. Since its the ECU that most likely is the problem your tune is gonna screw you concerning the warranty. I believe there is a TSB about the issue.
Riftur is offline   Reply With Quote
Old 04-09-2017, 08:42 AM   #9
Riftur
Riftur's Avatar
Here is the TSB thread
http://www.ft86club.com/forums/showthread.php?t=45844
Old 04-09-2017, 09:28 AM   #10
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
Too late, but was it possible to remove the tune before seeing the dealership? and flash back afterwards?
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
Braces is offline   Reply With Quote
Old 04-09-2017, 12:46 PM   #11
Roneezy
Roneezy's Avatar
Damn, is it too late for me then?
This sucks.... would it be possible to maybe get it flashed back to stock? Maybe I can take the car from them and drive over to delicious tuning and flash it back really quick! Lol
I got it flashed stage 1 by delicious tuning in January 2016, maybe if it locks them out from their factory reflash they'll think the ecu is broken too?.... Damn man, this sucks so much.
Old 04-09-2017, 02:06 PM   #12
Riftur
Riftur's Avatar
You can always try going to another dealer that has not seen your car yet.
Old 04-09-2017, 02:20 PM   #13
Roneezy
Roneezy's Avatar
Maybe reflash back to stock and seeing another dealer is a good option...
Good idea, actually didnt even think of that lol.
Old 04-09-2017, 03:00 PM   #14
steve99
Hello,
You might be lucky.
Since cam issues are quite well known and tsb issued etc, and you don't have aftermarket header they are probably not going to suspect or look for tune.
The TSB says to replace the ecu, they will just replace it , most likely without looking any further. You will then need to get the tuner to renew you ecu licience and tune.
However tunes are easy to detect, and unfortunately flashing back to stock with ecutek still leaves the licience in ECU, which alters the CVN (checksum value number) so can still be detected, but they may not look that hard if your lucky.
Need advice - major problems with Hotchkis kit GSX-R35 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 11-18-2016 02:48 PM
Buddy Club Race Spec Coilover Problems on Problems on Problems mpross Suspension | Chassis | Brakes -- Sponsored by 949 Racing 48 09-04-2016 11:18 PM
[Power Steering/Electrical/Warranty] Problems, could use some advice. Ajax969 Issues | Warranty | Recalls / TSB 7 07-26-2015 07:01 PM
BRZ/FRS problems... jdmgevo Issues | Warranty | Recalls / TSB 19 08-07-2014 10:54 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
