Old 04-01-2017, 07:21 PM   #1
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Flex Fuel use follow-up
I just want to bring to attention of long term use and how important to have a catch can setup property to collect ethanol vapors from the crank case. If not for the catch can these vapors can dilute my engine oil and cause engine failure.
Below is a picture of my catch can when I just put 600 miles on my car running nothing but Flex fuel back to back. These miles were not idle nor drive like an old man when on the the local interstate "i75". RPM range was 3-4k making my runs from south Florida to Clearwater Tampa.
In the past using 93 tunes I had some but very very little sludge. But with flex fuel the catch can filled up quickly. The fumes smell like vodka. A/F and tune has been perfect but oh boy I can see some people having problems. A proper setup to catch these fumes is REQUIRED if not the engine oil would degrade to 0w.
Catch can setup has 1/2 hoses running from both crankcase vents to a vent to atmosphere catch-can with a magnetic drain plug. The vent side of the catch-can has a hose that travels under the car and dumps next to the transmission because I don't want to smell that shit.
I like to share as much as I can so no one has to learn the hard way. Communication is key.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following 6 Users Say Thank You to GsxrMe For This Useful Post:
504 (04-03-2017), CxG (04-20-2017), Fred E (04-01-2017), ShawnP19 (04-05-2017), swarb (04-01-2017), Yoda (04-13-2017)
Old 04-01-2017, 09:10 PM   #2
swarb
Which catch can do you have? Some units catch more than others.
Old 04-01-2017, 09:35 PM   #3
GsxrMe
GsxrMe's Avatar
Custom. Didn't like the options on the market. I wanted the absolute best breathing, very little restricted flow from the crack case vents. The market everyone else sees is far tomuch markup and glammer.
Let me put it this way. Ethanol blow by is very high. Makes sense to because the car does spray 33% more fuel when running it. I guess the chance on making it past the piston rings so so much higher. Imagation if you had a catchcan not allowing flow correctly, either restrictive or recirculating back into your intake. Your oil would be screwed.
Im done doing highway runs for awhile so ill followup on this again with city driving.
2014 Subaru BRZ
Old 04-01-2017, 09:42 PM   #4
GsxrMe
GsxrMe's Avatar
Ethanol boiling temperature is 173.1°F after that point and turns into vapor if it's in your crankcase or oil caused by piston blow by. After that point travels to my catch can, cools down and turns back into a liquid.
Really makes me wonder if I just distilled the ethanol lol.
2014 Subaru BRZ
Old 04-01-2017, 10:09 PM   #5
Fred E
Drives: WRB BRZ
I'm having similar results and my PCV side catch can fills up with ethanol rather quickly these days. Definitely good info here, and also a reason to NOT use the type of catch can/AOS that drains back into the engine. You'd be draining all of this ethanol back into your oil and thereby accomplishing nothing.
Do you have any pictures and details of your catch can setup? I'd like to put a custom setup together some day as well.
Fred E is offline   Reply With Quote
Old 04-02-2017, 12:43 PM   #6
GsxrMe
GsxrMe's Avatar
I just purchased a generic 2 inlet catch-can from ebay. Installed a 1/2 barbs on the catch-can. Installed a 1/2 barb on the backside PCV crankcase and deleted the subaru valve altogether. Ran a 1/2 hoses from back crankcase vent and from vent to the catch-can. Took the filter off the catch-can and installed a 1/2 house instead and routed it under the car next to the transmission for dump.
I did have to go to HomeDepot and purchase an aluminum 1/4 sheet metal to make the battery bracket to hold on to the catch-can. I painted the bracket black to match. All said and done I was under $100
2014 Subaru BRZ
Old 04-02-2017, 01:39 PM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
You deleted the PCV valve?
It's actually a necessary component to the engine especially the long life of the engine. running an open PCV may have worked a long time ago, but it has to be sealed and working properly. http://www.agcoauto.com/content/news/p2_articleid/197 read this.
Old 04-02-2017, 02:08 PM   #8
GsxrMe
GsxrMe's Avatar
Gone, entirely, its just a barb now. No point to having a check valve as my setup dumps to atmosphere and not recirculated.
Pressure in the crankcase causes issues. Lets not use a check valve thats intended for the intake to pull fumes from the crankcase during idle.
2014 Subaru BRZ
Old 04-02-2017, 08:43 PM   #9
Amputechture
Drives: 2014 BRZ
I have a very similar setup to yours:
-PCV Delete
-Two -8 fittings going to a vented can
-Baffler/Filter screen thingie that rests between where both fittings sit
How much did you catch when you were running pump gas? I've been running 11 PSI now since the summer and haven't caught a single drop of oil. I am absolutely positive that it is set up identically to yours outside of a breather filter in place of your 'dump' hose...any thoughts?
Amputechture is offline   Reply With Quote
Old 04-04-2017, 01:38 AM   #10
Cal3000
Drives: Panda FR-S
lol. I have 110,000 miles on a boosted set up with no catch can. So far I ran 70k miles on e85. Took my engine apart and everything was clean. I could basically lick the spark plugs and not get sick.
I can say, for everyday driving, no catch can is need.
The only thing you need to do is change the oil at least every 7000 miles. The blow by does find it's way into the oil I think. I don't know if it is normal for the oil, but the viscosity gets reduced by a lot.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
86 South Africa (09-02-2017)
Old 04-04-2017, 07:10 PM   #11
Amputechture
Drives: 2014 BRZ
Thanks Cal, that is comforting to hear! I guess yours and my pistons seal better than some because I have seen next to no signs of blow by whatsoever. Granted I have not cracked the motor open like you have but I have nothing coating the inside of the charge piping, intercooler couplers and what have you. Some slight residue on the walls of the inside of the catch below the fitting openings but that's all. I do like knowing that my crankcase is being vented and that I don't have to worry about pressure leaking past the pcv and into the CC.
Old 04-10-2017, 09:35 AM   #12
GsxrMe
GsxrMe's Avatar
Ok update.
City driving with now and then WOT has nearly no blowby. Highway driving with WOT seems to be a different story.
2014 Subaru BRZ
The Following User Says Thank You to GsxrMe For This Useful Post:
Fred E (04-10-2017)
Old 04-10-2017, 09:49 AM   #13
Fred E
Drives: WRB BRZ
Originally Posted by GsxrMe View Post
Ok update.
I've also made the same observation. Both my the PCV and CCV side catch cans fill with ethanol rather quickly after some highway WOT.
Old 04-13-2017, 01:51 PM   #14
GsxrMe
GsxrMe's Avatar
-PCV Delete
Shoot, I didn't see your post. I'm running 11PSI and soon to be 20PSI.
2014 Subaru BRZ
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 06:43 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 06:21 AM
FS: Moto-East Flex Fuel Kit - OEM Fuel Pump FR-Shred Engine, Exhaust, Bolt-Ons 1 05-16-2016 06:28 PM
ECUtek Flex Fuel REVOLUTION: World's First Flex Fuel Factory ECU GTR - BRZ soon! Visconti Engine, Exhaust, Transmission 356 05-20-2013 09:36 AM
