Drives: 2014 Silver BRZ
Velox Clutch Fork Worth it?
Hey guys,
I was wondering if during forced induction applications with a heavy clutch is an upgraded clutch fork worth it? I know it must be if that part is prone to failure over load rate but im curious about others opinions and if you run the stock fork just fine and for how many miles. Also if your clutch fork has broken, do you dd or track the car. any input is appreciated thanks |
Drives: RHD Gt86
Yup it's worth it, got one for myself and the pivot to go with it
I also changed the clutch line to a braided one
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
| The Following User Says Thank You to Kris86 For This Useful Post: | why? (04-02-2017) |
#3 | |
Site Moderator
Drives: ichi 86 Project
| The Following User Says Thank You to ichitaka05 For This Useful Post: | why? (04-02-2017) |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
It's pretty much mandatory to install this fork with stiffer pressure plates included in aftermarket clutch kits.
Drives: frs
Yes
Thanks Guys for the input, ill pick one up. I was debating weather or not to get that or a strut brace and master cylinder brace LOL trying to budget but I suppose I need this.
Is it worth it? Fork yes!
Last edited by RJasonKlein; 04-01-2017 at 02:02 AM. Reason: Corrected a typographical error. |
Cannonball Record Guy
Drives: Series.Yellow, 4C, Fit
I got one (and the pivot) for piece of mind. My OEM fork was still in surprisingly good shape when I took it out at 64k.
Even though I went with a pretty conservative ACT HD pressure plate, I can still feel a substantial difference in pedal feel -- It's easier to engage the clutch pedal with the ACT HD PP w/ Velox over the stock PP w/ stock fork & clutch spring removed. The Velox piece just oozes quality. |
Drives: 2013 BRZ Limited
You guys should check out the DIF shift fork from FRSport. It's a really nice piece, solid, and the company supports NASA competitors. This part was developed prior to the competitor part, but wasn't advertised through the forum so I'm not sure if many people are aware of it.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523 Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car www.makesmodels.com www.camautomag.com |
| The Following User Says Thank You to zdr93523 For This Useful Post: | RedReplicant (09-10-2021) |
| Verus Engineering Billet Clutch Fork and Pivot | Drakiv | Engine, Exhaust, Transmission | 218 | 07-13-2023 09:45 AM |
| Clutch Fork Squeaks | fantah | Hawaii | 28 | 11-07-2018 02:22 PM |
| Velox clutch fork bnib | rixter145 | Transmission and Driveline | 3 | 01-28-2017 03:16 AM |
| Clutch Squeaks at the end of travel... clutch fork? | treminaor | Issues | Warranty | Recalls / TSB | 54 | 12-02-2016 04:53 AM |
| stiffer clutch= broken Clutch fork | KAR | Engine, Exhaust, Transmission | 1 | 04-25-2016 06:31 AM |
