Old 03-30-2017, 11:15 PM   #1
trex510
trex
Drives: brz
wheels, tires, and tpms
I am thinking of getting 17 x 8 oz ultraleggeras. I was wondering if 235/45/17 tires would be good for the wheels. and also would me not reprogramming the new tpms affect the speedometer?
trex510 is offline   Reply With Quote
Old 03-30-2017, 11:17 PM   #2
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
TPMS has nothing to do with the speedometer - the worst that will happen is you get an annoying yellow light in the left lower quadrant of your dash.
theadmiral976 is offline   Reply With Quote
Old 03-30-2017, 11:31 PM   #3
trex510
trex
Drives: brz
is the tire size good enough
Old 03-31-2017, 12:31 AM   #4
Brayden_23
Drives: Asphalt 2015 FRS
Should be fine. I run 235s on my 8.5" wheels. Would recommend a 235/40 instead though to mantain the same ratio as stock
Brayden_23 is offline   Reply With Quote
Old 03-31-2017, 03:17 PM   #5
Sosa
[||]--(86)--[||]
Sosa's Avatar
Drives: 2015 Firestorm FR-S
235/40 would keep stock diameter on an 18" wheel. OP will be running 17's so 45 will maintain stock diameter.
[||•]==(86)==[•||]
Sosa is offline   Reply With Quote
Old 03-31-2017, 03:51 PM   #6
Brayden_23
Oh right! Good call. Glanced over that tidbit
The Following User Says Thank You to Brayden_23 For This Useful Post:
Sosa (04-03-2017)
Old 03-31-2017, 04:32 PM   #7
SkyKing
Drives: 16 BRZ Limited CWP 82 Alfa Romeo
I'm going the same route with the OZ's and 225/17 but haven't decided on the 7.5 or 8's. I'll go to Subaru to have them sync the TPMS though. Nothing worse than an idiot light that's on all of the time. Doesn't the 235 plus the 8 give you some poke? Is it an inch?
SkyKing is offline   Reply With Quote
wheels, tires, and tpms trex510 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-31-2017 08:53 AM
WTB OEM BRZ wheels/tires/tpms Sayte Want-To-Buy Requests 0 10-22-2016 12:40 PM
FS: OEM Wheels + Tires + TPMS mortybryant Wheels and Tires 0 12-31-2015 03:18 PM
FS: OEM Wheels, Tires, TPMS (MA) superleggera Wheels and Tires 8 07-25-2015 11:07 PM
FS: FRS wheels + tires + TPMS (oem) NRG x FRS Wheels and Tires 3 10-16-2012 01:56 AM
