Old 03-28-2017, 10:39 PM   #1
twag4
Drives: frs
window issue
I have my engine out of my car, and the battery is obviously disconnected. I noticed that my driver's side window is in the slightly lowered position as if the door was open. The door was closed when I disconnected the battery. I am not sure how this happened. With the engine ecu removed from the car, is there a way to raise the window? I am going to have to load the car on a trailer and haul it without the engine and ecu, so I would love to get the window up in case of rain on the highway during the haul. Anybody have any ideas?
twag4 is offline   Reply With Quote
Old 03-28-2017, 10:51 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
I think if you just stuck the battery back in you could get power to the windows.
Either that or you could get clever with a weed whacker battery and a couple little jumper wires.
Old 03-28-2017, 11:15 PM   #3
humfrz
Yep, Bubba suggests
humfrz
Window issue after window replacement Gabzor Issues | Warranty | Recalls / TSB 11 03-03-2017 05:48 AM
Window Reset Issue finch1750 Issues | Warranty | Recalls / TSB 2 12-19-2016 04:26 PM
Driver Side Window Issue kevinchavarria Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-27-2016 11:28 AM
Driver window issue? Off track? s14sleepyeyez Issues | Warranty | Recalls / TSB 7 06-07-2013 08:19 PM
passenger window issue =.= Jeong Issues | Warranty | Recalls / TSB 0 03-13-2013 08:19 PM
