Old 03-26-2017, 09:54 AM   #1
Yoda
Drives: Crystal Black BRZ(Sophia)
Will it Fit?
Looking to replace the stock seat with some Recaro Style XL Seats. Does anyone know if it will fit?
DIMENSIONS & WEIGHT
Weight Style XL: 51 lbs / 23 kg
Weight Style XL Topline: 54 lbs / 25 kg
Max Height: 35.8 inches / 910 mm
Max Seat Cushion Depth: 21.3 inches / 540 mm
Max Seat Cushion Width: 21.1 inches / 535 mm
Yoda is offline   Reply With Quote
Old 03-26-2017, 10:09 AM   #2
Cole
Not a troll
Cole's Avatar
Do you not know how tape measures work?
The Following User Says Thank You to Cole For This Useful Post:
swarb (03-26-2017)
Old 03-26-2017, 10:22 AM   #3
Yoda
Just asking for a bit of help. Not sure what to measure or where. This is unfamiliar to me so just reaching out to see if maybe a similar spec seat has been installed. Are you able to assist with this inquiry?
Old 03-26-2017, 10:49 AM   #4
Cole
Not a troll
Cole's Avatar
Yeah, the width, height and length will be the limiting factors for install. Take the measurements of the seat, then compare them with the space available in the car.
Old 03-27-2017, 07:17 AM   #5
Kestrel
Kestrel's Avatar
Drives: 2015 Ultramarine FR-S AT
Installing seats heavier than stock...🤔😯😫
Sent from my SAMSUNG-SM-G900A using Tapatalk
Kestrel is offline   Reply With Quote
Old 03-27-2017, 10:47 AM   #6
arkanist
Drives: 2016 BRZ Limited, Stock
Some people don't fit comfortably in the stock seats, nothing wrong with that.
arkanist is offline   Reply With Quote
