Old 03-21-2017, 12:46 AM   #1
Impureclient
Drives: 2015 FR-S
Do lightweight wheels make the car faster?
So I'm debating on taking off my Enkei M52 17x7.5 (20 lb) wrapped in 225/45 Michelin PSS (22lb) and pushed out with spacers (approx 1.5 lb)
and swapping them for Flowform720 GTF1 17x8 (15.5 lb) wrapped in 245/40 Michelin PSS (23 lb) and no spacers for a total savings of 5 lbs at each corner.
I planned on doing this to get better acceleration and performance out of it and not so much for the looks since I am happy with it presently.
Then I got to looking at what real world difference is and not just seat of the pants dyno data and came up with this article below.
Their 4 lb difference is pretty close to the 5 lbs at each corner I hoped to save but their results tell a different story that what I was led to believe on wheel/tire weight performance.
So what's the deal?
Impureclient is offline   Reply With Quote
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
Frisco (03-21-2017), TommyW (03-21-2017)
Old 03-21-2017, 02:22 AM   #2
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Narrower, shorter, sticker tires will make a bigger difference in performance than lightweight wheels. What lightweight wheels/unsprung mass will do is improve the ride quality. Suspension can work more efficiently and quickly with less force/mass for it to have to control, this becomes more apparent the worse the surface condition is - smooth surfaces minimize the differences. I'm using a 17lb wheel (17x7.5 +40mm offset Enkei Fujin) and 19lb tire (205/45-17 Continental ExtremeContact DW) setup and would never want to go back to close to stock mass again...car is much more nimble and responsive to input, and more stable with the associated CG drop from the tires. And less effected when the road surface becomes less than optimal...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 03-21-2017, 02:28 AM   #3
OzzyGT86
OzzyGT86's Avatar
Drives: Ultramarine GT86
That article seems to contradict all of my beliefs and butt dyne "sessions" so I can see why you would be confused. However all I can really do is give a real world experience that I felt when moving to lighter wheels. My first set up was a 18x9.5 Rays Gramlight 57dr with 255/35 tires and the car did feel a bit slower than the stock 17s. However when I finally decide to pull the trigger on some light weight wheels I ended up with 17x9 RPF1s with a 255/40 tire. For me it was a night and day difference in acceleration. I actually felt the car move while in a high gear at a low RPM. I feel that maybe the reason why I felt such a difference was because first of all I went from a 18in wheel to a 17in wheel, I upgraded from a street tire to an r compound tire and I went from a wheel weighing almost 22lbs to a wheel weighting 15.6 lbs. In your situation I don't feel the difference will be that noticeable and the resources may be best used elsewhere. Just my two cents
OzzyGT86 is offline   Reply With Quote
Old 03-21-2017, 04:45 AM   #4
ZZT86
ZZT86's Avatar
Drives: BR86
What about the spacers, wouldn't you have to tack that weight onto the Enkeis? Surely that's extra weight the hub has to rotate yes ?
ZZT86 is offline   Reply With Quote
Old 03-21-2017, 09:03 AM   #5
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
I think the biggest issues with their test is the buttery smooth track. But also note in that little blurb in the end with a larger difference the lighter wheels were slightly better.
As their drivers noted, lighter feels better while driving. Sometimes that confidence is more important. But 4 or 5 lbs is not that big of a difference.
Old 03-21-2017, 09:25 AM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Originally Posted by Vracer111 View Post
(205/45-17 Continental ExtremeContact DW) ...
205?
The Following User Says Thank You to TommyW For This Useful Post:
Somerandom18 (03-21-2017)
Old 03-21-2017, 11:05 AM   #7
Yardjass
Yardjass's Avatar
Drives: '14 Monogram, '95 Miata, '90 300ZX
A tenth of a second on a short track or cone course is not enough to account for human error between laps.
There's also rotational moment of inertia to consider, which is simply put, how much the wheel resists the torque applied to it. It is possible, although unlikely, for a heavier wheel that has more of its mass concentrated towards the inside to actually have a smaller rotational moment of inertia than a lighter one. That and/or the fact that the tires should affect it much more than the wheels could account for the machine not noticing a difference.
Yardjass is offline   Reply With Quote
Old 03-21-2017, 12:35 PM   #8
DuMa
DuMa's Avatar
Drives: LR BRZ Limited
it also helps the steering feedback
DuMa is offline   Reply With Quote
Old 03-21-2017, 12:52 PM   #9
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
I agree with most of what has already been stated... just want to add a couple small points and clarify:
1) Rotating mass has a noticeable affect on braking...
2) As mentioned, the radial distribution of rotating mass makes a large difference. Your spacers don't affect acceleration/braking as much as your tires do, since the weight is close to the axis of rotation.
3) Light wheels can flex more contributing to slower lap times - ideally you want very strong, light wheels.
Unsprung mass helps handling, as stated above; however the original article changed too many things (as I fear you are doing) to draw a conclusion about the wheel's contributions to speed. Tire width contributes to rolling resistance and grip, and as mentioned diameter effectively changes final drive ratio for all gears. Almost all of a tire's weight is at the farthest point from the axis of rotation.
All of these changes are small/subtle, and the effects can be additive or cancel each other out. If your car is NA and you are trying to maximize acceleration and performance, I personally would stick with 225s. A NA car really does not need a 245 for performance and the 225 will weigh less and have less rolling resistance. That said I doubt the difference is meaningful to anything other than your wallet.
nextcar is offline   Reply With Quote
The Following 2 Users Say Thank You to nextcar For This Useful Post:
Shinchu (03-21-2017), TommyW (03-21-2017)
Old 03-21-2017, 01:14 PM   #10
TommyW
TommyW's Avatar
Here's a question for you as I'm on the fence between 245 40 17 and 225 45 17. The 245's are a lb lighter so do you feel that with the added rolling resistance but lighter weight it would be a wash on straight line performance? I'd imagine overall the 245's would be better when you consider cornering in the equation of overall performance? Thoughts?
Old 03-21-2017, 01:41 PM   #11
nextcar
It depends on the brand and model of tire - I will take MPSS as an example.
245/40R17 is a pound heavier - and only 0.3 inches shorter, I seriously doubt anyone would feel a difference. The 245 will be more expensive, and with NA power levels very, very few people will be able to take advantage of the additional traction. As mentioned in the original quoted article the overall tire diameter can make a noticeable difference in speed.
Really this is a coin toss for you... unless it is part of a larger set of complementing changes I seriously doubt you will notice any difference at all
The Following User Says Thank You to nextcar For This Useful Post:
TommyW (03-21-2017)
Old 03-21-2017, 03:05 PM   #12
Yardjass
Yardjass's Avatar
It depends on what wheels you are putting them on too. You aren't doing yourself any favors squeezing a 245 on a wheel that should have a 225 or less on it, and messing up the rigidity of the tire's sidewall. Literally all you're doing is causing the sidewall to bend inward in a way that it wasn't designed. This ultimately is doing nothing but tacking on extra width (weight) at best and reducing your tire's ability to do their job at worst. Alternately, getting wide wheels and stretching tire that is too narrow onto it is going to save you some weight but will also negatively affect your tire's ability to do their job.
Old 03-21-2017, 03:41 PM   #13
TommyW
TommyW's Avatar
right, thanks. Want to go 8" so I can use a 225 or 245.
Old 03-21-2017, 04:28 PM   #14
JT.86
Drives: Scion FRS 2016
if you're worried about that 5 lbs, just go on a diet. :/
___________________
2016 MT|Varis Arising II body kit with carbon add-ons|Aimgain x Stancenation Spoiler|Valenti Japan Jewel headlights|Valenti 4th Brakelight|ST-X coilovers|SPC LCA|18x10 TE37RT|Hankook Ventus RS3 265/35|Work Chrome blue lugnuts|Corsa catback|JDM TOM's red taillights|JDM armrest|TRD carbon Fender garnish|Beatrush Rear bumper brace|Cusco front strut
JT.86 is offline   Reply With Quote
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" GuerillaRacing Wheels and Tires 116 01-20-2015 06:32 PM
TWS Forged Wheels T66-F - Ultra lightweight Race Wheels with Style // DSG Performance Jason@DSG Wheels and Tires 37 12-17-2014 02:50 PM
Can stickers make your 86 Faster? ntron1 BRZ First-Gen (2012+) — General Topics 21 04-14-2014 02:03 PM
Lightweight wheels or wide wheels Moetivegt86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 11-06-2013 10:57 PM
