Old 03-20-2017, 08:57 PM   #1
Sagz
Drives: 2016 Brz Hyper Blue
18x8.5/18x9.5 255-225 or 265-235?
Hi, I've been doing some research on what tire I should choose for a while now, but I still have a few questions I can't find a clear answer for.
I'll be running 18x8.5 (front) and 18x9.5 (rear). I can't decide if I should use 255/35 and 225/40 or 265/35 with 235/40.
- I do not want a stretch tire or very little as I am still on stock suspension and i think it would look weird. Will 225 and 255 look too stretch? I'm less worried for the 255 than the 225 as it seems that the 225 is the minimal recommended size of a 8.5 wheel and 255 a recommended size for 9.5(If you guys can give me any clear picture can't find one anywhere with the right angle..)
- The 255 setup is about 1.5% bigger from am and the 265 3%. Is it something to consider or both are minimal and won't hurt anything?
-I also see a lot of people run 235 (3% dif. with oem) with 255 (1.5% dif. with oem) shouldn't the wheel have the same circumference or as close as possible without going too far from Oem specs?
-Lastly, I'll be running FireStone FireHawk Indy 500 at least that's what I'm currently considering. I can't find if those tires are larger than other tire in the same size like ''Michelin Pilot Super Sports''. Which would help with less stretch with the smaller size.
Thanks for your help!
Sagz is offline   Reply With Quote
Old 03-21-2017, 06:16 PM   #2
Justadandao
Drives: 2013 Scion FR-S 10 series
I have same size wheels help
I got the same size wheels this week. Let me know what size you decide on. I didn't buy tires for mine because I can't find a solid thread that has the same set up. If anyone can point us in the right direction let us know!
Justadandao is offline   Reply With Quote
Old 03-21-2017, 06:20 PM   #3
Sagz
I actually bought the tire today should get them installed tomorrow, I went with 225/40 and 255/35 to keep the ratio as close as OEM, I'll take pictures of the streets (Good ones), but I won't have my car for at least 2 weeks since its in storage, I'll still post pictures with Stock suspension if it helps once i get it.
The Following User Says Thank You to Sagz For This Useful Post:
derekbrz24 (03-21-2017)
Old 03-21-2017, 09:22 PM   #4
Justadandao
Thanks man
Looking forward to the pics!
Old 03-22-2017, 09:21 PM   #5
Sagz
Here are a few pictures I took from the stretch on both size wheels. The strech isn't that bad if at all. If you want bubbly tire, perfectly ''square/flush with the wheel look'' or if you want to protect the lip from hitting a curb ''if you ever do so'' get a larger tire. Both 225/40 and 255/35 are more ''rounded towards the inside'' then stretched.
I'm really happy with the outcome, now only waiting to get the car out of storage! I think fitment will be perfect, even with stock suspension, will update when I get a chance
Thanks, hope it helps! if you have any question, feel free to ask!
Wheel Size: 18x8.5
Tire Size: 225/40/18
-Wide view-
-Strait edge just to show strech-
-Close up-
Wheel Size: 18x9.5
Tire Size: 255/35/18
-Wide view-
-Close up-
derekbrz24 (03-23-2017)
Old 04-03-2017, 03:00 PM   #6
Justadandao
Front Pics
Can you post pictures of the wheels/tires head on/first person view?
Old 06-25-2017, 10:08 PM   #7
Sagz
Sorry for the delay, I just saw your reply, Hope you got the size you like. I'll add pictures for others!
FS - Work XT7 18x8.5+38/18x9.5+38 OR 18x9.5+38 all around 5x114.3 drftxx Wheels and Tires 6 07-13-2014 01:45 AM
Gauging interest Enkei RS05RR 18x9+40/18x8.5+50/18x8.5+42 THMotorsports.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-19-2013 04:33 PM
Considering going from 18x8.5ft/18x9.5back to 18x9.5 squared what to expect?? OICU812 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 07-18-2013 10:10 AM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
