Old 03-19-2017, 12:29 AM   #1
stevo585
Drives: White 2014 BRZ
Odd boost taper
Recently installed a JDL turbo kit. The tial wastegate has the 8.5 psi spring with no boost control. However during ecutek street tuning boost would only hit 7.x psi and then taper to 4.x psi up top.
Any ideas? Visually everything looks ok. I would assume a massive boost leak would be probable or a wastegate malfunction which I'm sure is rare.
Another odd thing is the car runs and idles fine otherwise. So the leak must be far from the MAF??
JDL Turbo kit - Ecutek, HRI tuned.
stevo585 is offline   Reply With Quote
Old 03-19-2017, 05:50 AM   #2
steve99
malfunctioning BOV ?
Old 03-19-2017, 10:41 AM   #3
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
I'd suggest to check for vacuum boost / leaks 1st and also check that the throttle is fully open
Matt@Cosworth is offline   Reply With Quote
FS: AEM Tru Boost rixter145 Audio/Visual, Electronics, Infotainment, NAV 9 01-29-2016 04:13 PM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
BRZedit and boost. (also wondering BRZedit vs ECUtek with boost) NickFRS Software Tuning 43 03-10-2014 04:10 AM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
