Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > CANADA > Canada Classifieds
Old 03-18-2017, 03:43 PM   #1
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
FS: Wilwood/RR Racing Stage 1 BBK - $1000
Just realized my old post was deleted
I'm selling my stage 1 wilwood bbk for a Subaru BRZ or FRS - Will also fit 5x100 Subarus. The kit does not require dual drilled rotors, the kit is fully upgradable to the stage 3 floating rotors, my kit uses 1 piece rotors. The kit has been used approx 10k km and a couple track days.
Why is this kit awesome?
-pads can be changed in seconds with a single pin holding in both pads from the top
-each caliper is 4lbs lighter than oem
-the stage 1 kit uses thin, but longer calipers which can be cleared by stock BRZ wheels with only an 8mm spacer!
-17x9 +35 rpf1 which are super common will clear these wheels
-they are red
-rotors still have 90% left
I want to note that at the end of the summer I had a seized piston which was repaired properly by removing and splitting the caliper then rebuilding it. I have used the kit all winter on my car and it has worked flawless.
Canehda is offline   Reply With Quote
Full Blown's New Build for the 2015 Season Stage 3 (2.19L motor) + Stage 3 Turbo kit FullBlown Forced Induction 47 06-20-2018 02:38 AM
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
Exedy Stage 1 Failure: Advice + Stage 2 Questions Pneub Engine, Exhaust, Transmission 4 07-18-2016 09:24 PM
