Old 03-09-2017, 12:45 PM   #1
Alejandro45
Drives: FRS Scion 2016
Thumbs up FRS on 18x10 Offset +30 Fitment Question
Hi FRS and BRZ enthusiast here is the question on my wheels
FRS on 18x10 Offset +30 my tires are 225/35/18 (is 225-35-18 ok to drive fast ? on 10 inch wheels ? ) now everything fits fine but. I will like to know for a 10 inch wheel with offset+30 can I use a larger size on tires kipping the 35 aspect ratio, just a wider tire with out having fitment issues, oh my car is lower 2 inches on coil-overs. Here are the possible tire sizes that I like 235/35/18 and 245/35/18 I will like to go as wide as possible. Any positive feed back is welcome.
Thanks in Advance for all the help
Alejandro45 is offline   Reply With Quote
Old 03-11-2017, 04:13 PM   #2
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Well if your car is lowered 2 inches 235 will rub without camber. My 225 on a 9.5 rubs (more than likey it rubs due to 40 profile) but I am around 3 inches low. 225 on a 10 will be pretty stretched l. You mentioned drive fast, how fast are you talking I personally would not speed on a stretched setup just to be safe. If I were you I would consider a 245 or better for the 10.
Old 03-11-2017, 04:43 PM   #3
wparsons
wparsons's Avatar
225 fits best on an 8" wheel, it'll be stretched too much on a 10" wheel for any sort of performance driving IMO.
flickr
Old 03-11-2017, 07:16 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Just run 275 or wider tires on a 10" wide wheel and you can go as wide as possible.
-alex
tires help, wide tires
Offset and fitment on Varis Widebody davidshu0327 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 03-31-2020 10:20 PM
Fitment Check: 17 X8.5 with +44 offset USDM TOYOBARU Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-27-2015 11:36 PM
Offset/spacers related generic BBK fitment wise trends churchx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-21-2015 03:39 PM
Need Opinions on Wheel Offset (+35 or +15) for Flush Fitment Dustin2JZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-30-2013 08:33 PM
