Old 03-09-2017, 12:00 AM   #1
RedRez86
RedRez86's Avatar
Drives: Red Scion Frs
Need some help with overpipe, front pipe, catback combos
Okay so I'm pretty sure I want to go with the greddy evo3 cat back which is 2.75 inched.. My question is will a 3 inch overpipe and front pipe seamlessly connect with this cat back or will I need matching 2.75 inch over and front pipe and where do I find them? If I need to go full 3 inch exhaust I will still be sticking with greddy exhaust (maybe perrin) but where can I find more 3 inch over/front pipes. I can't find many and all are rather expensive. I saw a one piece 3 inch over/front pipe but read reviews that it will sag and I would need to add engine mounts which I would like to avoid. Please feel free to air your opinions! Thanks guys!
Sent from my SM-G935T using Tapatalk
RedRez86 is offline   Reply With Quote
Old 03-09-2017, 06:45 AM   #2
Reamer
Drives: 2015 FRS
I'm pretty sure you want to run a full ACE exhaust.
Disclaimer: I'm not a rep for ACE, just a happy customer.
Reamer is offline   Reply With Quote
Old 03-09-2017, 09:43 AM   #3
RedRez86
RedRez86's Avatar
I only see 1 full ace exhaust and it's only center outlet. I am looking for dual exit cat back and 3 in pipes. Also something that won't scrape when I lower my car.
Old 03-09-2017, 09:51 AM   #4
jasonojordan
Drives: 2013 satin white brz limited
Question that should be asked is do you plan to go FI (forced induction aka turbo supercharger)? If not then no reason to run 3".
jasonojordan is offline   Reply With Quote
The Following User Says Thank You to jasonojordan For This Useful Post:
Tcoat (03-09-2017)
Old 03-09-2017, 09:52 AM   #5
RedRez86
RedRez86's Avatar
Yes it will have a turbo in the near future. All mods are purposely being planned ahead.
Old 03-09-2017, 11:15 AM   #6
CSG David
CSG David's Avatar
We have a CSG Touring86 catback exhaust that is 70mm (2.75"). We have clients with turbo and supercharged applications running it for both performance and improve sound quality over shear noise. Let us know if you have any other questions. Thanks!
Old 03-09-2017, 11:25 AM   #7
RedRez86
RedRez86's Avatar
I just need to know if 3 inch over pipes and front pipes will seamlessly connect with 2.75 inch or 3 inch catbacks
Old 03-09-2017, 12:34 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
It depends on the exact ones as different holes in the flange may align a little different but generally speaking it should be fine. Add some rtv to the gaskets if you are really worried.
You have to think most 2.5" pipes added to smaller diameter stock.pipes end up ok and this is basically the same thing
Old 03-09-2017, 12:38 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Depends on who makes it.
Any front pipe utilizing stock donut gasket will neck down to that point.
Any exhaust utilizing stock donut gasket will neck down to that point.
Worrying about exhaust piping without understanding what it bolts up to is not solving your problem.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Tcoat (03-09-2017)
Old 03-09-2017, 12:41 PM   #10
RedRez86
RedRez86's Avatar
-alex
I do not understand.
Old 03-09-2017, 12:44 PM   #11
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Kind of the point he was trying to make.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
finch1750 (03-09-2017), Tcoat (03-09-2017)
Old 03-09-2017, 12:48 PM   #12
CSG David
CSG David's Avatar
There is an adapter flange that you can run for the 3". A client is running 3" overpipe/front pipe to a 3" to 2.5" flange mated to the CSG Touring86. The Touring86 flange is designed to mate to a 2.5" front pipe outlet. It has been done.
The Following User Says Thank You to CSG David For This Useful Post:
RedRez86 (03-09-2017)
Old 03-09-2017, 12:50 PM   #13
RedRez86
RedRez86's Avatar
Okay I am asking for help not to point out my lack of knowledge on the subject which was the initial reason for me posting this thread in the first place. Makes sense? Thanks.
Old 03-09-2017, 12:58 PM   #14
mav1178
mav1178's Avatar
If your exhaust can bolt up to the stock front pipe, it will neck down to the inner diameter of the stock donut gasket.
To say "I have a 2.75" exhaust and will it mate up to this or that front pipe or overpipe" is focusing on the wrong issue, because there will be a bottleneck known as the stock donut gasket.
So, if you want a 2.75" or larger exhaust system (which includes front pipe for purposes of this discussion), you need to consider 1) whether your exhaust of choice reuses the stock donut gasket, and 2) if this singular bottleneck is going to cause you any problems with flow.
If you are running a basic bolt-on FI kit, this is not going to be a bottleneck for you in terms of power. If you are going to do a kit and up it to 10-15PSI or more of boost, then you should consider an exhaust or front pipe with a flat flange.
-alex
Edit: obviously if you don't care about the bottleneck then this is a moot point of discussion.
CSG David (03-09-2017)
OEM Header, overpipe, front pipe and catback for sale Christopherkuchta Engine, Exhaust, Bolt-Ons 9 12-03-2015 03:02 AM
WTB: Overpipe/front pipe and catback ionhsmith Want-To-Buy Requests 4 09-25-2015 11:18 PM
Header, Overpipe, Straight pipe, Cat back Diameter options/ Combos FT_86_SM_GP Engine, Exhaust, Transmission 3 03-23-2015 08:32 AM
Perrin Catback & Overpipe and HKS front pipe. Vorshlag SS brake lines Rotarynerdette Engine, Exhaust, Bolt-Ons 14 04-23-2014 10:43 AM
Agency Power Catback/front pipe & Overpipe (Brand New!) 20FRS13 Engine, Exhaust, Bolt-Ons 13 01-22-2013 03:08 AM
