Old 03-07-2017, 04:04 AM   #1
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
Valenti taillight hyperflashing
So I've had my Valenti tails for over a year now. Worked fine until today.
Left the house to go to the grocery store, taillights worked fine on the way there. Got back into my car, heading out of the parking lot and turned my right turn signal on, started hyperflashing out of nowhere. Not sure what could be the cause of this. Didn't do anything different to my car, or at least with the taillights in a while.
This happened at night and I can describe what happens to the taillight when I turn on the turn signal. The left taillight is normal, while the right side boomerang flashes on and off. The yellow arrow doesn't light up, only the brake light and boomerang does. Could this be a faulty relay (using the stock one) or a messed up fuse? Hopefully that its just my car that is messing it up, will try on a friends car and see what happens.
[ame="https://www.youtube.com/watch?v=5ddwfm6ziu4"]Valenti taillight issue - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=1SboFV23e70"]Valenti taillight issue - YouTube[/ame]
thecarfilmer is offline   Reply With Quote
Old 03-07-2017, 05:21 AM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Probably neither. The relay works on the indicator circuit, it doesn't do anything to the brake or light circuit. A fuse would cause the lights to stop working completely.
If you think about it, the rest of the light is illuminating when you indicate so it sounds like an issue within the light, perhaps a short or similar. As this then bypasses the internal resistors that would explain the hyper flash. What happens when you leave just the lights on or brake? Is it the same when indicating with the lights off?
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-07-2017, 05:26 AM   #3
thecarfilmer
IG: @nickwiththefrs
When the lights are on, the boomerangs stay on and the brake lights light up. Turning the turn signal to the right will cause the right taillight to blink like that in the video. When the lights are off, both brake lights work. Just the right turn signal doesn't illuminate.
Old 03-07-2017, 05:29 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Then that definitely sounds like an issue within the light unit.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-07-2017, 05:31 AM   #5
thecarfilmer
IG: @nickwiththefrs
Not totally sure what is causing it to hyperflash either.
Old 03-07-2017, 12:31 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
Well the OEM relay hyperflashes when there is a drop in resistance to indicate a bulb has blown. If the circuit has shorted and is no longer passing through the resistor to the indicator then you'll get the hyperflash.
.: Stealth 86 :.
Kodename 47 DJ:
Need Red and Chrome Valenti Taillight zedthebrz Northern California 2 02-02-2017 08:20 PM
Valenti Taillight Repair...Any body tried it? lextrueno Cosmetic Modification (Interior/Exterior/Lighting) 7 08-11-2015 07:24 AM
Taillight Selection through Valenti/ModBargains ModBargains.com Cosmetic Modification (Interior/Exterior/Lighting) 57 08-03-2013 03:32 PM
Tom's vs. Valenti's Taillight GH05T Cosmetic Modification (Interior/Exterior/Lighting) 10 07-14-2013 11:26 PM
Taillight Selection through Valenti/ModBargains ModBargains.com Exterior Parts - Lighting 3 04-26-2013 08:50 PM
