Old 02-28-2017, 05:04 PM   #1
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
Help Greddy turbo timer
Can someone please help me with the wiring for this thing? I feel like I've tried every possible combination and there is no plug in harness for our car.
Please before you said not to waste my money, know that I got the turbo timer for free off a friend.
Thank youa
Sent from my SAMSUNG-SM-G930A using Tapatalk
drambo136 is offline   Reply With Quote
Old 03-01-2017, 02:11 PM   #2
drambo136
drambo136's Avatar
Bump
Old 03-01-2017, 02:25 PM   #3
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
Not a waste of money depending on the type of turbo you're running and how/where you're driving your car. But what do you mean tried every combination? This is not usually a plug and play item, as you have to tap into your ignition wiring. Where are you struggling exactly?
Toyarzee is offline   Reply With Quote
The Following User Says Thank You to Toyarzee For This Useful Post:
drambo136 (03-01-2017)
Old 03-01-2017, 02:31 PM   #4
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Wow, haven't anyone talk about turbo timers since the 90s. Just let your car idle for 30 seconds before shutting it down. Most modern turbos don't need 5+ minutes to cool down and get the oil through.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 03-01-2017, 03:04 PM   #5
drambo136
drambo136's Avatar
I'm struggling with which wires to tap. There are two 12v constant wires, two ignition on wires and one accessory wire. I've tried what seems like every combination of these wires but doesn't seem to work.
Old 03-01-2017, 03:06 PM   #6
drambo136
drambo136's Avatar
Ya I do that now but I got the turbo timer for free so that's why I want to use it
Old 03-04-2017, 12:11 PM   #7
drambo136
drambo136's Avatar
Bump
Old 03-05-2017, 08:27 AM   #8
denso
Drives: 86
Im using a turbo timer to shupt my oil scavenge pump off after i shut down the car. I made a wiring diagramm myself. I will have a look at it and will post it.
denso is offline   Reply With Quote
The Following User Says Thank You to denso For This Useful Post:
drambo136 (03-05-2017)
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
Apexi Turbo Timer for oil scavenge pump denso Electronics | Audio | NAV | Infotainment 0 08-08-2016 04:32 PM
Anyone know how to install a apexi turbo timer? steve86gt DIY (Do-It-Yourself) Guides 1 04-25-2016 08:44 AM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
