Old 02-28-2017, 12:06 AM   #1
Zeezy
Drives: Black 86 GTS
Wondering if I dun goofed
I recently got new wheels and tires for my car and I think I may have chosen the wrong tire size.
Wheels are 18 x 8.5 and Tires are 245/40 R18
This wheel and tire combo increases the overall diameter by ~27mm (~1 inch)
In hindsight I feel like I should have gone with 245/35 R18 or 235/40 R18
Is this 1 inch increase in diameter too much?
What impact will this increase have?
Thanks in advance!
Zeezy is offline   Reply With Quote
Old 02-28-2017, 12:36 AM   #2
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
It will basically increase your overall gear ratio. Which may have a little effect on how quick your car is, but will give it a higher top speed (and higher in each gear)
It will also change the accuracy of the speedometer. Chances are it read a few MPH faster than you were actually going when stock. Now it might read a little slow. Remember this will change depending on speed. For example now you might be going 31 and only show 30 and might show 70 but be going 74.
You can do some measurements and a little math and get a good idea of where you will be.
SCQTT is offline   Reply With Quote
Old 02-28-2017, 01:57 AM   #3
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
According to this: https://tiresize.com/calculator/
Your actual speed will be 4.5% higher than what your speedometer reads.
PandaSPUR is offline   Reply With Quote
Old 03-01-2017, 04:59 AM   #4
tyler_win_photo
tyler_win_photo's Avatar
It'll make the car feel slightly sluggish compared to stock and possibly look a little odd. If you're not tracking your car, you shouldn't have much to worry about. Like others have said, just keep in mind that your speedo is going to read lower than your actual.
tyler_win_photo is offline   Reply With Quote
Old 03-01-2017, 06:49 AM   #5
nikp
Drives: 2016 BRZ
You'll find that the speedo reading lower from your tire diameter change is pretty much offset by our cars reading faster from factory.
Go download a GPS speed app and drive at a constant speed. Look at your speedo and compare it to the app.
nikp is offline   Reply With Quote
Old 03-01-2017, 07:00 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
It's also going to affect your grip levels and balance. If you have not done any power mods, it'll make the car harder to drift and probably a little more boring to drive.
Old 03-02-2017, 06:22 PM   #7
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
In short? Yes. You goofed.
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
Old 03-02-2017, 06:28 PM   #8
Kendallkab
Drives: Black MT LMT BRZ
Just curious.. did you see the thread under this and then started to think you goofed?
Kendallkab is offline   Reply With Quote
I dun goofed into a curb sittinSideways Scion FR-S / Toyota 86 GT86 General Forum 17 03-30-2015 11:00 PM
I dun goofed... need help identifying interior wire Turbowned BRZ First-Gen (2012+) — General Topics 26 05-17-2014 10:51 PM
Subaru dun goofed: what steering wheel controls? Turbowned BRZ First-Gen (2012+) — General Topics 9 03-20-2013 10:25 AM
I dun goofed.. RIP BRZ thelegaCy BRZ First-Gen (2012+) — General Topics 90 11-04-2012 04:54 AM
i dun goofed? Andyx5044 Scion FR-S / Toyota 86 GT86 General Forum 30 10-26-2012 11:19 AM
