Old 02-22-2017, 08:31 PM   #1
Nah
Drives: 2013 Scion Frs 6mt
Boost supporting mods for the street
About to pull the trigger on a JDL kit. But first what supporting mods for the motor will I need To safely run 8psi 10-12 max.
Besides the basics (mounts, catch can, oil cooler)
Anything I should be aware of?
Nah is offline   Reply With Quote
Old 02-22-2017, 08:42 PM   #2
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
A proper tune and boost gauge. Maybe consider an upgraded radiator, since you're in FL.
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
Nah (02-24-2017)
Old 02-22-2017, 11:32 PM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Forged internals
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
Nah (02-24-2017)
Old 02-23-2017, 08:06 AM   #4
Fred E
Drives: WRB BRZ
For strictly street driving, engine mounts aren't completely necessary, but are also cheap relative to the benefit they provide. A catch can is a great idea, as well as a larger capacity clutch. You might be able to get away with the stock clutch for a while as long as you don't do any hard launches, but it will eventually give out. Any clutch that has a torque capacity of at least 250-275 ft-lbs should be fine for the street.
An upgraded radiator isn't strictly necessary unless you're tracking, and technically an oil cooler isn't either. I was using an oil-to-air oil cooler for a while, but my oil never got up to operating temperature while driving on the street, which is obviously not ideal (good read: http://www.ft86club.com/forums/showthread.php?t=114293). If anything, an oil-to-water (i.e. OEM style coolant-based) oil cooler would be sufficient. If you are going to be taking the car to the track, definitely get both an upgraded radiator and an oil-to-air oil cooler.
You should also think about upgrading injectors only if you're going to be using ethanol. The OEM pump does not actually need to be upgraded either way, regardless of what many people will likely say (source: I was pushing almost 400whp on ethanol with the OEM fuel pump for a long time.)
Fred E is offline   Reply With Quote
The Following 2 Users Say Thank You to Fred E For This Useful Post:
Nah (02-24-2017), ShadowReaper (10-23-2017)
Old 02-23-2017, 12:12 PM   #5
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
Is this the new JDL kit priced at 2999$?
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
Old 02-23-2017, 02:24 PM   #6
TRACE_on
TRACE_on's Avatar
Drives: 2023 GR86 - Track BRed Premium 6M
For street use with pump gas, you don't HAVE to upgrade anything else IMO. Even the stuff you listed isn't necessary. Clutch will likely start slipping sooner or later so a stronger unit might be needed.
STR also-ran
TRACE_on is offline   Reply With Quote
The Following 2 Users Say Thank You to TRACE_on For This Useful Post:
Old 02-23-2017, 04:22 PM   #7
Super Dave
Stuck In a Sandbox
Drives: FRS RS1.0
i had to upgrade my injectors but my kit was making 13psi.... as long as you stay around 11 it should be fine
Super Dave is offline   Reply With Quote
The Following 2 Users Say Thank You to Super Dave For This Useful Post:
Old 02-24-2017, 10:40 AM   #8
Lonewolf
Lonewolf's Avatar
Drives: Moped
A wideband gauge was always cheap insurance with a boosted car when I grew up...I don't think things have changed that much
Old 02-24-2017, 11:16 AM   #9
D_Thissen
D_Thissen's Avatar
Does AEM still make the failsafe one?
edit: so they do http://www.aemelectronics.com/files/..._Failsafe.html
The Following User Says Thank You to D_Thissen For This Useful Post:
lextrueno (10-24-2017)
Old 02-24-2017, 09:42 PM   #10
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Everything on my tag was required to get the car to run right. My factory mounts lasted 5k miles before I felt the motor wanting to jump out when i was in traffic coming from a stop to give it alittle gas.
You can take all the shortcuts you want but id do it right the first time. Tune is a 100% must imo
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-23-2017, 06:25 PM   #11
ShadowReaper
Indulgent Tormenter
ShadowReaper's Avatar
Drives: 15' LTD Subaru BRZ DGM
Thanks for sharing your experience. I am debating getting injectors fuel pump for this kit but I do notice most people on this forum are tracking, I'm just street driving/ DD... and to be fair I have seen MORE successful builds on forums with stock internals and turbo than UNSUCCESSFUL builds with stock internals
Any good recommendations on clutch and catch can?
Instagram: Gabe.it.the.ole.college.try
ShadowReaper is offline   Reply With Quote
Old 10-23-2017, 06:32 PM   #12
sachu
Drives: rocketship
catch cans
Motor mounts (just cause you might as well)
oil pressure gauge
oil cooler (especially if doing spirited driving)
upgraded Clutch.. I went with the ACT SB8-XTSS (Versus forged clutch fork and pivot as well, since you're already in there)
tires/wheels
edit: Most important of all, a proper tune. Just say no to "tooners"
sachu is offline   Reply With Quote
The Following User Says Thank You to sachu For This Useful Post:
Fred E (10-24-2017)
Old 10-24-2017, 08:45 AM   #13
Fred E
Drives: WRB BRZ
I had a rather terrible experience with an ACT clutch from day 1 and have had an amazing experience with a South Bend clutch and the stock flywheel. A stage 1 daily clutch (295 ft-lbs, part # FJK1005-HD) or a stage 2 daily (315 ft-lbs, part # FJK1005-HD-O) depending on your torque level. I'm currently using the stage 3 daily clutch rated for 400 ft-lbs and it feels almost as easy as stock and SO much better than the ACT XT I was using before. There's also hardly any flywheel chatter on deceleration, unlike the ACT street-lite flywheel that was deafening loud on deceleration and even chattered at idle with the A/C on. Imagine sitting at a traffic light with the A/C on next to someone with their window down. I did also have a separate issue with the ACT clutch failing and letting go in the middle of a redline pull at only ~200 ft-lbs of torque (4000 rpm or so maybe?). The only reason I went with another of the same was because it was covered by ACT's warranty.
The Radium catch can kit is the cleanest and best looking kit in my opinion and if you're boosted or going to be, you should probably get the dual kit. After seeing the junk that my catch cans have caught, I highly recommend against getting one that drains what it catches back into your block.
Also as mentioned directly above, a proper custom tune should be step 1.
The Following User Says Thank You to Fred E For This Useful Post:
ShadowReaper (10-24-2017)
Old 10-24-2017, 02:15 PM   #14
ShadowReaper
Indulgent Tormenter
How long have you been FI with stick internals?
All kinds of boost! Innovate, HKS, AVO, Greddy, Full Blown + supporting mods! No Limit Motorsport Forced Induction 214 05-23-2017 03:45 PM
E85, what are the best supporting mods? ProjectMidnight86 Engine, Exhaust, Transmission 9 06-25-2016 02:56 PM
What supporting Mods do you REALLY need? Adrian002 Forced Induction 27 05-09-2015 08:27 PM
turbo kit supporting mods lbroskee Forced Induction 13 03-30-2013 08:56 PM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
