Old 04-19-2011, 09:21 AM   #1
BoostJunkie
RaggedEdge Autosports
BoostJunkie's Avatar
Drives: 97 APU Supra
WhatsYourFuelSetup???
Just wanted to see what everybody uses on their DD or track car?
Also how's your setup? Are you running more pumps? Bigger injectors? SteelBraided lines? A/M FPR? Post Up!!
APU Supra- Dual Denso Fuel pumps, Titan intank pump Hanger, 850cc injectors(for now) BoostLab FPR, all on pump (93oct.) Or c16(116oct.)
Also post which car with which fuel if you have mult cars
Red JZA80 APU Supra 800whp
White 07 Turbo Si 411whp *RIP*
BoostJunkie is offline   Reply With Quote
Old 04-19-2011, 09:51 AM   #2
Dragonitti
Older fuel setup
550cc RC Eng injectors
Stock pump
Old fuel setup
750cc RC Eng injectors
Stock pump
New setup coming soon
900cc PnP injectors
Full Return fuel system + Swirl Pot
Deatsch Werks 300LPH Fuel Pump
Old 04-19-2011, 10:18 AM   #3
BoostJunkie
Older fuel setup
Stock pump
Old fuel setup
Stock pump
900cc PnP injectors
Swirl pot? Is that like a serge tank?
Old 04-19-2011, 10:36 AM   #4
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
for now big bore fuel rail, 550cc injectors, modified OEM fpr, walbro pump (that appears to be getting weak).
ugh, i'm not looking forward to dropping the tank again to put a new pump in.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Old 04-19-2011, 10:42 AM   #5
BoostJunkie
As am I not either, I'm going to a triple denso pump setup when I get the EFR turbo
Old 04-20-2011, 09:56 AM   #6
BoostJunkie
Wow, I thought this thread would have had more responses, everybody running stock fuel out there?!? Or am I just used to the crazy need for more fuel in the Soup community?
Old 04-20-2011, 11:56 PM   #7
Dimman
Kuruma Otaku
Dimman's Avatar
Still stock (440's). Around half your power so...
Because titanium.
Old 04-21-2011, 07:27 AM   #8
BoostJunkie
Im about to have a big sail, the stock twins, stock rims, everything! I'll let you know when I do if your interested in anything I got
Old 04-21-2011, 10:25 AM   #9
Dragonitti
Keeps fuel from sloshing around by being a separate tank. Will allow me to continue to race at full speed and hit those right handers without getting fuel cut because I'm running below half tank of gas.
Old 04-21-2011, 07:45 PM   #10
4agze
4agze's Avatar
Drives: Toyota Corolla SR5
on my SR5 corolla I have a 8 gallon bladder inside the original gas tank from a friends fuel safe fuel cell that he gave me, I didnt want to cut and make a hole on my trunk so next idea was insert the bladder it self & it looks cleaner like an OEM. then its pumped by a MSD external pump, earls fuel lines w/ fittings, 4agze AE101 oem injectors.
4agze is offline   Reply With Quote
