Old 02-15-2017, 06:51 PM   #1
boozinix
Bought a used FR-S, it didn't come with a keyfob. What to do?
Hi
I recently purchased a used 2013 Scion FR-S (for cheap , sort of) in SF Bay Area. Now, the car only came with a single manual key, no fob, which works well to manually unlock the car and start/operate it.
Now, I do want to get a keyfob to lock/unlock the doors. I talked to my local dealership, they are asking for $240 for new oem key and $80 to program it.
I wanted to know if I get a $17 key from ebay (http://www.ebay.com/itm/Replacement-...JYEWos&vxp=mtr), have it cut, can I self program it just to lock/unlock doors? I saw some threads here which list the steps to do that. Is that good enough? What else does the "programming" at dealership include?
Also, best-buy offers remote start and security system for $250 . If I just get something like that, would that fob be good enough for what I am looking for?
Thanks for reading.
boozinix is offline   Reply With Quote
Old 02-15-2017, 10:08 PM   #2
stevesnj
stevesnj's Avatar
contact a dealer
My 2016 Build thread
Old 02-15-2017, 10:35 PM   #3
sgtcarrot
Drives: Scion FR-S 2015 Blue and stock
There are a whole bunch of posts, the above one is the short answer.
The long answer is that this is pretty complicated, in part because of a) the chip in the key and b) the radio transmitter that is programmed to the car. Obviously for security ( we do not want just anybody able to copy and open any car) these are coded, and any other solution other than working with the dealer will be time consuming, sketchy, and very much likely to not work.
I have seen some people get around this by installing a push start system, but that seems like a lot of work.
Consider that you saved money on the purchase price specifically because of this, pretty much everybody would need to go to the dealer. Sucks, but it is a great car, you will love it, and the convenience (plus having a spare key) is well worth it.
Anyways, that is my take having lurked here these past few years, good luck with whatever approach you take. (Google search this site for older, lengthier posts,they are here).
sgtcarrot is offline   Reply With Quote
Old 02-15-2017, 10:38 PM   #4
tCsonfrs
Drives: 10 Series FR-S #207
Originally Posted by boozinix View Post
Hi
Thanks for reading.
"Programming" as you put it includes making the key work with the immobilizer system, and the remote part work with the car. It also deletes any previously programmed keys ro remotes from the car, so make sure to leave your old key with them at the time of programming so it doesn't become obsolete.
tCsonfrs is offline   Reply With Quote
Old 02-15-2017, 10:59 PM   #5
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
I will just recommend OEM.
FR-Sky is offline   Reply With Quote
Old 02-16-2017, 08:19 AM   #6
VoltsFRS2013
VoltsFRS2013's Avatar
Drives: 2022' GR86 Premium 6MT
Your valet key should of hopefully came with some sort of tag that has an ID for the key, if you contact the dealer and provide that information you should be good to go, key fobs obviously aren't cheap though.. might be a few hundred to get the replacement.
VoltsFRS2013 is offline   Reply With Quote
Old 02-16-2017, 01:16 PM   #7
boozinix
For the Fob, I have seen a range, from $17 on ebay (http://www.ebay.com/itm/Replacement-...JYEWos&vxp=mtr ) to some running $170 online. What's the difference, I can't seem to confirm?
Like I said, dealer wants $240 just for the key only?
Old 02-16-2017, 01:18 PM   #8
boozinix
Thanks for the reply, and sorry for being a noob here, but does the immobilizer prevents the car from being start if unlocked manually? Right now, I have no fob or any unlocking keyless method. I only have a simple manual key, to manually unlock the doors without any fob.
So if I get a cheap key off ebay, can i just use it to lock/unlock doors without the immobilizer system?
Old 02-16-2017, 01:21 PM   #9
boozinix
Hello, thanks for the detailed response. Im curious, if I goto Bestbuy for something like this ( http://www.bestbuy.com/site/remote-s...?skuId=5518501 ), can I get away without going to a dealer for a key fob system? Like I said, I have a fobless key, which manually unlocks doors and thats it. Don't believe there is any functioning immobilizer system on it yet.
Old 02-16-2017, 01:46 PM   #10
86geek
86geek's Avatar
Drives: 2015 FRS Asphalt
If you're willing to spend $189.99 for that IMHO just get the fob and get it programed by the dealer.
Opti-Coat & Cquartz Finest, Apexi Drop in Filter, 2.5 Perrin Res. Catback Exhaust
86geek is offline   Reply With Quote
Old 02-16-2017, 01:53 PM   #11
boozinix
Dealer is still $350 for ONE key...
Old 02-16-2017, 02:18 PM   #12
SocalMonsta
SocalMonsta's Avatar
Drives: White FRS
That sounds expensive. Maybe contact another dealer, but chipped keys tend to be v complicated. Also, the ppl in this thread are giving you a lot of false info, just stick w past posts.
SocalMonsta is offline   Reply With Quote
Old 02-16-2017, 07:36 PM   #13
Zhangy
Drives: 2015 FRS
your dealer fking stole it to make you pay for replacement...
Zhangy is offline   Reply With Quote
Old 02-16-2017, 07:43 PM   #14
boozinix
Yes I am trying to get another quote but I am going to guess that's going to be normal for everyone of them.
If I do the following with the ebay key, would I just be able to lock/unlock the doors? (http://www.fjcruiserforums.com/forum...-existing.html)
fob, fr-s, key, key fob, keyless entry
PSA-Keyless entry keyfob in clothes washer didn't ruin mine TheRatsWon BRZ First-Gen (2012+) — General Topics 2 02-13-2017 09:06 AM
FI Guys: Were you more excited when you bought your car, or when you bought boost? husker741 Forced Induction 28 02-25-2014 03:57 PM
If the BRZ/FR-S didn't exist, what would you have bought? R8 Other Vehicles & General Automotive Discussions 229 11-22-2013 01:14 PM
Does the Toyota Corolla keyfob cover fit the FRS keyfob? FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 6 07-25-2013 05:04 PM
Tired of your prius keyfob? WillBRZ BRZ First-Gen (2012+) — General Topics 41 01-24-2013 11:15 PM
