Old 02-05-2017, 10:51 AM   #1
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
(SOLD) Jackson Racing N/A Engine Oil Cooler Kit
SOLD
Jackson Racing Oil Cooler kit with hardware and instructions. This is the normally aspirated version. If you want to convert it to the FI version, I think all you'll need is the different mounting bracket from Jackson Racing. The other components you should be able to grab from any hardware store, which are a hose barb, small hose clamps, and a short length of hose. This oil cooler kit worked VERY well. Props to Jackson Racing for designing a very efficient kit that is a subtle addition after the install. My oil temps on a 73F day at Sebring were 284F and climbing, the next day it was 84F and I didn't bother even checking. Bought the oil cooler a few days later. After that, the highest oil temp I EVER saw was 228F at Road America in 80F ambient temp. It affected coolant temps a little. With an OEM radiator, I never saw above 208 coolant temp. Great kit!
The only thing missing from this kit is the hardware (2 push lock nuts, a bolt, and a threaded stud) to mount the oil cooler bracket to the frame. You should be able to get these from Jackson Racing for not much money at all. If that fails, they should be able to tell you exactly what you'll need.
Great condition, minor knicks in one of the lines. I'd like $450 for the kit shipped.
There are two knicks in the lines. One is very minor, the other a little larger. There are NO leaks at all, but dropping the asking price of the kit a little. Shouldn't be an issue to strengthen that spot, plenty of options.
Apex_BRZ is offline
Old 02-05-2017, 09:05 PM   #2
Apex_BRZ
Oil cooler kit has been sold!
Apex_BRZ is offline
Jackson Racing engine oil cooler for NA applications CSG Mike Engine, Exhaust, Transmission 107 12-01-2021 04:03 PM
FOUND: Jackson Racing Engine Oil Cooler Kit (JRSC version) asnatlas Want-To-Buy Requests 2 05-20-2016 11:27 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
