Old 02-03-2017, 09:24 PM   #1
tofurun
tofurun's Avatar
Drives: 2014 BRZ Limited 6MT
intake cam OB
Anyone had any problems tuning for turbo and the intake cam going out of bounds out of boost low rpms?
tofurun is offline   Reply With Quote
Old 02-04-2017, 05:53 AM   #2
steve99
Shouldnt throw cam cel codes if it is then you likely have a problem with can actuator sproket, oil control valve or the can sensors or even the ecu. Their are a number of tsb on cam issues your ecu firmware should be B01C\D or later version
tofurun (02-04-2017)
Perrin Cold Air intake CAI (black) and AVO silicone intake tube (blue) Joesurf79 Engine, Exhaust, Bolt-Ons 13 07-29-2016 02:38 PM
Okada / Ignition Projects / Cusco / Megan / aFe Intake & Filter / Agency Power Intake eauto Engine, Exhaust, Bolt-Ons 299 10-15-2014 01:44 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 06:06 PM
