View Poll Results: Edelbrock vs Speed by Design 400x/500x
Edelbrock 67 55.83%
SBD 400x (Complete Bundle Package) 22 18.33%
SBD 500x (Complete Bundle Package) 31 25.83%
Voters: 120. You may not vote on this poll
Old 02-01-2017, 02:30 PM   #1
nijat12
2015 FR-S RS 1.0 - Miami
nijat12's Avatar
Drives: 2015 Scion FR-S R.S 1.0
Edelbrock vs Speed By Design 400x/500x
I'm trying to pick between the two.
My car is DD for now (might turn it into a project car in 3 yrs - not sure).
My goal is to go FI while staying reliable and not spend too much (don't want to upgrade the clutch, injectors, etc) right now. Would be nice to be able to upgrade later if I want more power (not sure if I will want more)
It seems like Edelbrock is more reliable for DD. However, SPD owners are also very happy with their kits.
Edelbrock is a bit pricier than SBD500X (Complete Bundle Package) while putting out much less power. Their torque curves seem similar (might be wrong on this).
They both seem to offer everything for me to install (or have it installed)
nijat12 is offline   Reply With Quote
Old 02-01-2017, 04:16 PM   #2
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
sort of different kits, the best would be finding someone near you with each kit (or at least edelbrock vs turbo) so you get a feel for what each is like.
Can't really go wrong with either though
Old 02-01-2017, 05:21 PM   #3
scottman
scottman's Avatar
Drives: 13 mt fr-s
in my opinion, supers are much more reliable than turbos.
BUT turbos are much more fun. the lag is fun, the blow off can be super fun.
but.. i'd go super, if i could go back.
scottman is offline   Reply With Quote
Old 02-01-2017, 06:56 PM   #4
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
The SBD500X does indeed put out more power... but any more power than the edelbrock and you will need a clutch. So you need to factor that in as well.
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
gtengr (12-08-2017)
Old 02-02-2017, 03:30 AM   #5
Xxyion
Lowly Cartuber
Xxyion's Avatar
Drives: 2016 BRZ, 2005 Honda S2000
I currently have the Edelbrock kit. Its a great kit and if you get a Delicious tune you can put down some decent power with some nice low end torque. Also it has the pedigree. Edelbrock has been building engines and boosting them since the late 40's. It's also one of the best built kits out on the market.
SBD kit however is the best bang for your buck in terms of dollar per horsepower. Pretty simple to install and you have a few different ways to tune the kit as well as it supports the OpenFlash Tablet. It's modeled off the Greddy Turbo kit so reliability seems to be pretty good.
The benefit ti the Edelbrock is the CARB legal tune you get with it. I'm in California so that was a no brainer to me. It also makes the best mid range power out of all the SC kits out there.
Since you are in Florida i'd highly recommend the SBD kit. Don't have to worry about CARB and you have more space to take advantage of being closer to 300 who.
Don't get the 500 kit unless you plan on building your engine. that kit can easily push 400hp on 93 octane and more on e85. With the 400 kit you can run lower boost (which ups reliability) and come up right below 300 whp which won't compromise your engine life. It will also make it so you won't have to buy a new clutch for a while.
If reliability is a big must then strongly consider the Edelbrock. The benefit to running a supercharger is you don't need any supporting mods (catch can, oil cooler) unless you plan on tracking the car. Also power isn't as big of an issue especially if you don't want to upgrade your clutch. With the right tune and fuel you can easily hit 270 whp.
Remember you can really only pick two, reliability, cost, power
2016 Limited MT WR Blue BRZ | Delicious Flash n Go Tune | Delicious Flex Fuel Kit | Nameless 2.5" with 5" Mufflers | JDL UEL Headers | Bayson R Diffuser/Side Skirts | APR Front Splitter | VIS Racing GT Wing | ST Suspension Coilovers | Grammlights Rays 57CR 17x9 +38 | Sumitomo HTR Z iii 235/45/17 |
Xxyion is offline   Reply With Quote
The Following 2 Users Say Thank You to Xxyion For This Useful Post:
86 South Africa (09-26-2017), kitlives (05-19-2018)
Old 02-02-2017, 06:36 AM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
If you go with Edelbrock i'd personally get a clutch first. The power from any FI will make the stock one wear a lot faster, and once the supercharger is on, the slave cylinder is a pain to get to, so it's easier to do the clutch before.
Old 02-02-2017, 07:21 AM   #7
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Do you want to hear a wine or whistle?
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 02-02-2017, 07:43 AM   #8
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
GTHachiRoku is offline   Reply With Quote
The Following 10 Users Say Thank You to GTHachiRoku For This Useful Post:
86 South Africa (09-26-2017), CSG David (02-03-2017), HachiRokuX (09-15-2018), HUNTERANGEL121 (02-23-2017), JoeC (09-27-2017), kch (02-02-2017), LOLS2K (02-02-2017), MisterSheep (02-08-2017), PandaSPUR (02-07-2017), sactownbwoy (02-12-2017)
Old 02-02-2017, 08:04 AM   #9
chaoscentral
Drives: 2013 Scion FR-S Series 10
If the edelbrock whined, I would have been all over it. Every video I've ever seen it is more or less silent. The Sprintex whines like an SoB. If I could get that on an edelbrock I'd be in heaven lol
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
chaoscentral is offline   Reply With Quote
Old 02-02-2017, 11:15 AM   #10
continuecrushing
yup, everything I've seen points to the edelbrock kit being quiet
Old 02-02-2017, 11:16 AM   #11
Xxyion
Lowly Cartuber
Xxyion's Avatar
Can confirm, it's suuuper silent. I can hear it every now and then but generally only starting from a dead stop.
Old 02-02-2017, 11:51 PM   #12
TRDan
Drives: 2015 BRZ Limited 2005 Toyota Tundra
I just made this decision and for the first time in over 20 years of modifying cars went with the Edelbrock supercharger. I have had many turbo cars over the years (Turbo E36 M3, multiple RX7s etc) and the supercharger is...different for sure. The blower feels like the car just has a larger engine, there is no violent hit like with most larger aftermarket turbos. Also heat management with the supercharger seem better with the packaging limitations. I guess only time can tell if I would have rather gone turbo but I am enjoying my choice so far.
The Edelbrock kit was one of the nicest and most complete FI kits I have ever installed on a car.
Also a second on the Edelbrock being quiet, with the heat exchanger so far back most people probably cant even tell the car is modified.
TRDan is offline   Reply With Quote
The Following User Says Thank You to TRDan For This Useful Post:
CSG Mike (09-26-2017)
Old 02-03-2017, 12:44 AM   #13
Elliott S
Elliott S's Avatar
Drives: 2015 Subaru BRZ
Sbd 400x is pretty much the best kit you can get IN MY OWN OPINION. Ive been running an sbd kit for 13k miles at 10 psi/93 octane and hasnt missed a beat. Chris offers full and CONSTANT (he listens/replies to everyone) support, multiple upgrade packages, package deals with kits, and several different deals depending on the time of year. As far as the turbo v SC debate, you'll always have people on both sides of the fence. I'd do what others have suggested and try to find a vehicle with a turbo/supercharger and ride in it. I had the advantage of riding in a Vortech V3 before I purchased my SBD and I am VERY happy that I did.
Tl;dr
SBD is a bangin' deal, Chris is literally ALWAYS there for any questions (or just ask the FB group), and you get to hear the prominent stututututu.
Elliott S is offline   Reply With Quote
Old 02-03-2017, 01:50 PM   #14
Xxyion
Lowly Cartuber
Xxyion's Avatar
Tl;dr
SBD is right now really hitting that legendary unicorn of good power good reliability and low cost.
I dont hear too many horror stories of this kit failing on people. However i havnt read on any long term reliability. Only thing close is someone ran 80k miles on a Vortech Supercharger. I'd love to see numbers on people who have ran this kit for something close to that number.
Now if only they could get it CARB certified but put out the same power...=D
edelbrock, spd, speed by design, supercharger, turbo
Speed by design turbo kit Bigbell224 Engine, Exhaust, Bolt-Ons 12 05-26-2016 11:43 PM
Speed by Design + Vishnu OFT Tune MrStickers Forced Induction 5 03-21-2016 09:28 AM
Vortech vs. Speed By Design-Need advice raven1231 Forced Induction 21 03-25-2015 10:05 PM
Review: Pro Street Coilovers from Speed By Design ericmpena Suspension | Chassis | Brakes -- Sponsored by 949 Racing 67 03-08-2015 12:00 AM
Speed By Design Lug Nut SALE! spdbydesign Wheels and Tires 0 10-01-2014 04:54 PM
