Old 01-30-2017, 08:25 PM   #1
Tomo3101
Drives: ..
LED door sill help needed
Hi, guys I just found these:https://goo.gl/zL0951 on Ali express and thought they would look pretty cool in my 2012 86GT. I was wondering if any of you have these installed or experience with an installation of this type and could let me know the difficulty of it.
I will greatly appreciate any kind of advice you guys can give me,
Thanks.
Tomo3101 is offline   Reply With Quote
Old 01-30-2017, 08:40 PM   #2
KnightRyderx2
Drives: 2014 FR-S
I had led door sills on my Camry and it was easy to install. I dont have experience with these specific ones though.
The set I bought for my Camry were stick on with 3M tape, some use the plastic tabs like stock ones. Since mine were 3M, I had to reapply the tape every several months. As for wiring just connect the positive to a constant 12v and then connect the negative to the door switch wire in the door jam. This way they will come on when that door is open and be independent of each other.
KnightRyderx2 is offline   Reply With Quote
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
Tomo3101 (01-30-2017)
LED Door Sill? joergasm Cosmetic Modification (Interior/Exterior/Lighting) 46 06-17-2014 07:37 PM
door sill inserts Signature Products Want-To-Buy Requests 0 09-26-2013 05:29 PM
Door Sill Plate Special Signature Products Announcements, Contests, Giveaways 0 08-10-2013 10:17 AM
Door Sill padding coming off encity5 Scion FR-S / Toyota 86 GT86 General Forum 6 04-19-2013 12:30 PM
Door sill lights? jazztennor Cosmetic Modification (Interior/Exterior/Lighting) 7 11-15-2012 03:49 PM
