Old 01-24-2017, 01:25 PM   #1
Prmspen
Student Driver
Prmspen's Avatar
Drives: 2016 Subaru BRZ Limited
How Are RE-71Rs In The Wet?
I'm looking to get some Bridgestone RE-71Rs for street class autocross. Does anyone have experience running them in the wet? The tire description mentions reduced hydroplaning resistance, but the TireRack survey gives them a good score in the wet. I'm trying to figure out whether I can leave them on the car for the autocross season, or have to switch out rims/tires for each autocross event (yes, I'm a lazy SOB).
I live in the Pacific NW, so there would be plenty of wet-weather driving involved, both at autocross events and just daily driving to/from work.
Prmspen is offline   Reply With Quote
The Following 2 Users Say Thank You to Prmspen For This Useful Post:
mitch t (01-24-2017), NLS8520 (01-24-2017)
Old 01-24-2017, 01:43 PM   #2
slyphen
Drives: Man
Send a message via AIM to slyphen Send a message via Yahoo to slyphen
Lets put it this way. my time with RE71 was only .16 sec faster in the afternoon than my morning session with stock tires. both sessions were wet as hell.
similarly, Annie Gill is running with her MPSS instead of RE71s on a wet day.
slyphen is offline   Reply With Quote
The Following User Says Thank You to slyphen For This Useful Post:
Prmspen (01-24-2017)
Old 01-24-2017, 01:50 PM   #3
Prmspen
Student Driver
Prmspen's Avatar
Do you daily drive on the RE-71Rs at all, or just put them on for events? I'm also curious about whether they're safe to daily drive in a wet environment like the NW.
Old 01-24-2017, 02:42 PM   #4
slyphen
Drives: Man
they heat cycles out really quick so i dont daily mine. like you i swap them on when i get to the event. im in WA, so i know the feeling.
Old 01-24-2017, 03:20 PM   #5
GirlRepellent
GirlRepellent's Avatar
Drives: Evo X FE/FRS 10 Series
I run RE71Rs on my FRS and I've had them in the rain. I was concerned as well about Bridgestones wet driving warning. I only have 1 track day on these tires and about 9,000 street miles. Hydroplaning has not been an issue for me.
GirlRepellent is offline   Reply With Quote
The Following User Says Thank You to GirlRepellent For This Useful Post:
Old 01-24-2017, 03:35 PM   #6
PWBRZ
PWBRZ's Avatar
Drives: 2013 BRZ 6MT
Actually, I found the wet grip to be pretty good, with no odd surprises when they let go. The grip seems to fall off more in cold temps than it does in the wet. They would be fine for PNW daily driving but it is worth considering using them as a 2nd set for autocross/track only.
PWBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to PWBRZ For This Useful Post:
Prmspen (01-24-2017), slyphen (01-24-2017)
Old 01-24-2017, 04:09 PM   #7
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
What do you mean by this exactly?
Originally Posted by humfrz
I'm old and lazy
Old 01-24-2017, 04:38 PM   #8
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
They're fine in the wet. You may run into issues if you're low on tread and go through puddles, though.
G_Ride is offline   Reply With Quote
The Following User Says Thank You to G_Ride For This Useful Post:
GirlRepellent (01-24-2017)
Old 01-24-2017, 05:05 PM   #9
GirlRepellent
So true but wouldn't that be the case with any tire choice?
Old 01-24-2017, 05:12 PM   #10
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
They're called cheater tires for a reason: they're incredibly good in everything except snow and ice. The drop off between dry and wet (read: wet, not puddles) is not much from all the top folks I've talked to. However, they do drop off quickly so tire life is an issue but fresh tires to fresh tires, they're insanely good.
Especially if your driving is fast and quick right off the bat as opposed to building up over time.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
The Following User Says Thank You to Frost For This Useful Post:
Teseo (01-31-2017)
Old 01-24-2017, 05:15 PM   #11
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
They are great in the wet as long as full or near full tread.
justinco is offline   Reply With Quote
Old 01-24-2017, 06:40 PM   #12
slyphen
Drives: Man
With conventional tires, you usually judge how much life it has left by looking at the treads. The Bridgestone RE71Rs is a special compound tire, where it not only depend on the tread life, but also the amount of heat cycles. usually the tire loses its peak performance after a certain amount of heat cycles, this is the case with many high performance tires, including MPSS(but you may not notice unless you put the car into a competition environment).
Heat cycle is when the tire warm up to the design temperature and cool back down to ambient. The rubber compound loses its "stickiness" as it pass the optimal amount of heat cycles and become hard. RE71R is notorious for that, which is why right before the SCCA Solo National Championship, veterans are getting rid of their "older" RE71Rs even when they only raced 2-3 events with them. So if you daily them, you are putting it thru the cycles, and by the time you get to the track, its not as effective.
At least this is how i understood it by talking to the pros. hope it made sense.
The Following 4 Users Say Thank You to slyphen For This Useful Post:
Clipdat (01-24-2017), Prmspen (01-24-2017), PWBRZ (01-30-2017), Teseo (01-31-2017)
Old 01-24-2017, 06:57 PM   #13
Toyarzee
Shibby!
Toyarzee's Avatar
Drives: '14 White FR-S, '01 turbo mini taco
All true points, but with regards to daily, I sincerely doubt you're able to get enough heat into the rubber just driving around in the city where you would actually heat cycle out the tires, so this shouldn't be a concern unless constantly doing canyon runs in between track sessions where you actually work the tires.
Toyarzee is offline   Reply With Quote
The Following 3 Users Say Thank You to Toyarzee For This Useful Post:
Clipdat (01-24-2017), JoeC (01-24-2017), Teseo (01-31-2017)
Old 01-24-2017, 09:19 PM   #14
mitch t
mitch t's Avatar
Drives: stx class lava frs
I have a set on my FRS 265-35/18, and here is my experience.
1. At low speed, and with wet pavement but no standing water, they are very good. I imagine the compound is the important part in this situation, and it is excellent in the wet.
2. As speeds increase and the layer of water gets thicker,(as in even the shallowest of puddles) the tread shape and ability to channel water becomes the key, and then they are pretty bad. This tread shape makes a lot of compromise in order to maximize dry grip.
3. If I was dailying my car on the freeway, I would get another set of tires for the wetter months, but if I was only driving a few miles on side streets I might just try to get away with it.
mitch t is offline   Reply With Quote
The Following User Says Thank You to mitch t For This Useful Post:
Prmspen (01-25-2017)
