#1 | |||||
Drives: Toyota GT86
Timing compensation per cylinder
Extracting this topic from http://www.ft86club.com/forums/showt...=83945&page=38
Drives: Toyota GT86
So the update:
- So I added most of the total timing difference between the OFH tune and Wayno's 102 UEL stg 2 tune. - I zeroed out the TCPC A+B. - I copied the OFH IAT compensation for safety. The reason for flashing and logging was to check a slight MAF adjustment and hence it's without learning. Surprisingly I have no knock above 6k. The added timing at 3600 rpm is maybe too much (earlier in the log), but I know it will go slightly richer when it learns.I know this doesn't say much because no knock is detected. So it could be that I could run a bit more timing and still A or B cylinder might be the ones to knock first. Or they could run leaner without any chance to know as per Kodename47's suggestion. Or, worst case it could be that it knocks without it being detected (unlikely as per the knock sensor locations depicted above, I would think). I'm going to keep it they way it is for now and recheck this in the spring when we get higher temperatures. I also consider buying a knock sensor and an amplifier to make a DIY det can and see if it's possible to hear anything that the ECU doesn't. ![]() http://datazap.me/u/tor/tor-201?log=...-31-42&solo=17
Drives: Toyota GT86
The above post didn't get any feedback, but maybe someone will find it interesting later on.
I kept driving the car with the TCPC zeroed out. On the street with higher temperatures I still don't get any noticeable FLKC. On track it's another matter though. I drove 3x 15 mins stints and combined the log into one. So in 45 mins of combined track driving, this is the FLKC I got: First a count. This is the amount of times FLKC was activated (yes, almost 1200 times at 6800 rpm load 1.2): ![]() The mean values: ![]() And the max values: ![]() The high values (even the -4.47) didn't cause IAM to drop. I did have 3 instances of IAM drops. Once to 0.98 with a quick recovery. And once to 0.98 followed shortly after by a drop to 0.96. This, however, happened at 4000, 4200 and 4600 rpm where the FLKC values were low comparatively. In theory, I have no problems to continue driving with the current tune. The ECU pulls timing as it should and I get the most performance when driving the car on the street. However, I want to test if I can get better performance on track by reintroducing TCPC. The idea would be that perhaps the ECU would need to pull less timing overall if it's sufficient to take out some timing on cylinder A and B. From load 1.0 and up I will add the following compensations, based on the knock values seen above and looking a bit to the OEM TCPC tables: ![]() Will report back the result. Hopefully, I will have a chance to drive the car under similar track conditions in the near future. The intention is not to make FLKC free on track but to see if I can get it to pull less timing.
The Stig's German cousin
How do you know which cylinders are the slightly more knocky cylinders? Do you have knock count per cylinder?
My understanding of TCPC is that Subaru has a single knock sensor for the whole motor and it's placed closer to one bank than the other. Since it's possible for the far cylinders to knock lightly but not get noticed by the sensor, TCPC ensures that the first cylinder(s) to start knocking are closest to the sensor. Shiv probably removed TCPC as an optimization step for the aggressive OFH tune. It sacrifices an increased risk of undetected knock in order to encourage the ECU to be less aggressive about pulling timing. The onus is on the user to verify the tune and use good fuel. |
#5 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
Drives: UK GT86
@Tor don't forget that your cell count is not instances of knock detected retard but how many logged rows are less than 0. There is a difference, for example how many rows are there for just one decrease in timing? That will depend on logging and settings, but also you are including where the ECU is actually adding timing in after a retard event.
.: Stealth 86 :.
#7 | |||
Drives: Toyota GT86
I made a mistake with the data. When looking at the first log I noticed rpm spikes when the engine was at idle. And looking at video from the session, sure enough, I forgot to turn off the A/C. I wasn't aware that the A/C would cause actual FLKC. From what I read here previously, I only though I could cause false FLKC when clicking in and out.
Anyway, looking at log 2 and 3 only, it has a lot less knock. Perhaps so little, that I won't bother correcting it. The important take-away for me is, besides for all the other obvious reasons, never ever run with A/C on at the track. Count: ![]() Mean values: ![]() Max values: ![]() This is, by the way, a video of the 3rd session with Datazap log overlayed: [ame="https://www.youtube.com/watch?v=hC93-8wFo9E"]New season and personal lap record... Nürburgring GP circuit (GT86) - YouTube[/ame] Quote:
Drives: UK GT86
The AC shouldn't cause FLKC/FBKC. The clutch will disable at high load, this is no different to having it switched off. The frequency of it disabling the clutch shouldn't trigger the sensor either.
.: Stealth 86 :.
Drives: Toyota GT86
Here are the logs. The only difference is the A/C on. Otherwise ambient conditions the same.
http://datazap.me/u/tor/tor-2141-track-logs
| Don't know how to set timing. | MJferg | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 1 | 12-27-2016 09:36 PM |
| Movie Shooting - Stock WRB BRZ needed - Compensation provided | John Rambo | Southern California | 0 | 10-03-2016 02:14 PM |
| Individual cylinder timing maps | brn12345 | Software Tuning | 14 | 02-14-2014 05:44 AM |
| Compensation for CEL/SL | CharlieChaos | Issues | Warranty | Recalls / TSB | 89 | 11-08-2012 06:15 PM |
