Old 01-17-2017, 09:37 AM   #1
rsingh
Drives: gt 86
reverse signal wire on tail lights
there is a four pin cable connector on the tail lights does anyone know which colour is the reverse signal for a reverse camera?
rsingh is offline   Reply With Quote
Old 01-17-2017, 10:04 AM   #2
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
None. Reverse light signal is separate and located under the trunk, behind the bumper. (Unless the australian model is different?)
Also, this is a bad way to power reverse cameras depending on what head unit youre using. The stock head units test the backup cam upon start up to see if theres a signal, if not, it wont work even if you power it on later. So you'd have to start your car in reverse gear every time.
There are more threads with this info in detail, search around.
PandaSPUR is offline   Reply With Quote
Old 01-17-2017, 10:40 AM   #3
rsingh
Drives: gt 86
what colour is the reverse signal cable under the trunk? I have an aftermarket Kenwood head unit so this probably doesn't happen?
Old 01-17-2017, 10:55 AM   #4
PandaSPUR
PandaSPUR's Avatar
See here: http://store.ijdmtoy.com/Valenti-Sty...tion-a/617.htm
Old 12-23-2021, 01:12 PM   #5
nripinbabu@gmail.com
Drives: brz
Originally Posted by PandaSPUR View Post
is the green wire the reverse signal?
nripinbabu@gmail.com is offline   Reply With Quote
Old 12-23-2021, 08:52 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
What happens to the backup lights when you unplug it?
Old 01-28-2022, 02:21 PM   #7
Drives: brz
appreciate the tip, that was the reverse signal wire i was looking for.
Old 01-28-2022, 02:25 PM   #8
Ultramaroon
not playing cards
Bingo. No experience like first-hand.
SOLVED: No Reverse/Backup Signal or Lights sidetrak06 Issues | Warranty | Recalls / TSB 46 06-30-2025 09:42 PM
handbrake wire and reverse wire location Australia gt86 rsingh Electronics | Audio | NAV | Infotainment 0 01-16-2017 09:12 PM
Wire Valenti Reverse Light to Stock Tail Lights fizzymike Cosmetic Modification (Interior/Exterior/Lighting) 5 09-10-2016 03:57 PM
Tail Lights with reverse SmartedPanda Cosmetic Modification (Interior/Exterior/Lighting) 1 07-01-2014 09:47 AM
FR-S smoked tail lights and reverse lights jjdrivesajazz Cosmetic Modification (Interior/Exterior/Lighting) 43 02-21-2013 08:38 PM
