Old 01-07-2017, 09:55 AM   #1
NotTakumi
FT601US in FRS
I've searched everywhere, and still have one unanswered question.
I put a FT601US from a BRZ in my FRS, both 2013. Everything works, except the radio.
The only thing I haven't found is WHERE the wire from pin 8 needs to connect to.
Does anyone know?
NotTakumi is offline   Reply With Quote
Old 01-07-2017, 07:33 PM   #2
NotTakumi
Trying to power the antenna booster. The FRS antenna connector has one large wire for the antenna, and a smaller wire in the plug.
Running a jumper from pin 8 on the gen pin connector will supply 12v when the HU is in FM/AM/SAT modes, but I haven't found where the other end of the jumper goes.
Old 01-09-2017, 08:38 PM   #3
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
There's a post somewhere I used when I did it. I believe I just tapped into the ACC wire so as long as radio is power it is good to go
lbroskee is offline   Reply With Quote
Old 01-09-2017, 08:46 PM   #4
lbroskee
lbroskee's Avatar
" you would need to add a new pin/wire at pin #8 on your car's 10-pin power/speaker plug, and tie that to the smaller single wire (not the coax antenna cable) on your car's AM/FM plug."
That's what I did
