Old 12-17-2016, 01:01 AM   #1
softgrip
Drives: 2017 BRZ - Dark Grey Metallic
HELP: How much is too much power? :)
So, I have a 2017 DGM BRZ, with 18/9.5 wheels and 235/40/r18 Hankook RS3s.
I just managed to buy a lightly used SME Turbo kit with a GTX 2867r.
I should be able to get near 210-220ish atwkw (near 280-300hp) which was my goal....
but...here is the dilemma:
Also on offer for cheap is the following
Deatschwerks 1200cc injectors
Deatschwerks 300c pump in pre-modified pump cradle.
Invidia o/p and catted midpipe
Greddy Evo GT 3" catback
Extreme 230mm twin plate organic clutch
GFB GForce 2 electronic boost controller
Which on e85 will give closer to 300kw (400hps) if I want (apparently).
SO HOW MUCH BLOODY HORSES SHOULD I GET?!?
I want the car to be a fun daily spirited driver... with maybe a track day here and there.
I definitely do NOT want it to be unfun because it's too much of a beast, and hard to drive safely.
softgrip is offline   Reply With Quote
Old 12-17-2016, 01:53 AM   #2
steve99
Well 300hp at the wheels is pretty good you want to budget for at least an oil cooler and a clutch with even that setup.
with the 400whp setup well that probably pushing the bounds of friendship with a stock motor and driveline components if you want to drive it on track or hard with any sort of reliability and you still need oil cooler and clutch.
e85 can be hard to source in many places so you might need to consider flex fuel setup as well.
most people struggle to outdrive a stock car with basic mods like better tyres and brake pads
The Following 3 Users Say Thank You to steve99 For This Useful Post:
craigpitts7 (12-17-2016), Strife26 (08-20-2018), why? (12-17-2016)
Old 12-17-2016, 01:54 AM   #3
Cole
Not a troll
Cole's Avatar
Have you already mastered the stock power level? If not, doubling the HP isn't going to make it any easier to control.
The Following 2 Users Say Thank You to Cole For This Useful Post:
craigpitts7 (12-17-2016), Leonardo (12-17-2016)
Old 12-17-2016, 01:59 AM   #4
softgrip
well... I have flipped a BRZ...
I've come from a WRX, and driven modded WRX STI on track.
The Following 3 Users Say Thank You to softgrip For This Useful Post:
gramicci101 (12-17-2016), steve99 (12-18-2016), Ultramaroon (12-17-2016)
Old 12-17-2016, 06:49 AM   #5
Bobster
Drives: GT86 GTS
I have the same kit coming soon, 220wkw will need injectors and maybe a fuel pump. You will be lucky 200wkw without injectors with a little safety margin.
Bobster is offline   Reply With Quote
The Following User Says Thank You to Bobster For This Useful Post:
softgrip (12-17-2016)
Old 12-17-2016, 09:20 AM   #6
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Nah man you need 2000hp who cares about controlling when all we're gonna do is drive straight
Alltezza is offline   Reply With Quote
Old 12-17-2016, 10:47 AM   #7
bfrank1972
Drives: 2013 FR-S Argento
If you don't know, then go conservative. Especially if you've already flipped one.
bfrank1972 is offline   Reply With Quote
Old 12-17-2016, 12:32 PM   #8
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
205 is too much horsepower!
MS, CSCS, TSAC-F, CPT
Old 12-17-2016, 05:05 PM   #9
Stimmed
Stimmed's Avatar
Drives: Toyota 86
I would say 200-220 is the best bet on a stock motor on a decent reading dyno. You dont want to push all this power then be scared to use it worrying about the engine busting up etc.
Alot of people have been on 200-230 in QLD and haven't had any issues with the right tune. I think if you start pushing past that you become worried and cant just enjoy it as much.
Unless your planning on building later then go for it push it and have fun :P
2013 Toyota 86 (IQOf86) - Coyoda Turbo Kit, Perrin 3" Exhaust, 18" CE28SL's, Custom Oil Cooler/Transmission Cooler, Tuned by Coyote Tuning, Built FA20, E85 Fuel, Turbo Kit and Oil Coolers installed by Turbo Yoda
Stimmed is offline   Reply With Quote
The Following User Says Thank You to Stimmed For This Useful Post:
Old 12-17-2016, 10:36 PM   #10
johl
johl's Avatar
Drives: toyota 86
Sounds like you bought the used kit from import monster? Fantastic value and I was tempted but I'm holding out for a twin scroll efr kit.
I've driven a low boost 86 with around 220 or 240hp and that was super fun. I think initially I am only shooting for 300hp with a new clutch, oil cooler and fuel. Any more than that and you have to worry about gearbox and drive shaft failures.
As long as you get a setup that will let you choose more power later then you can't go wrong. You just don't want to be buying 2 turbo kits just because you want 100 more hp
johl is offline   Reply With Quote
The Following 2 Users Say Thank You to johl For This Useful Post:
COO86L (12-20-2016), softgrip (12-18-2016)
Old 12-18-2016, 05:03 AM   #11
softgrip
Yeah, Aaron's kitted me up with some good stuff. The pics of that DGM BRZ from last week are mine
The Following User Says Thank You to softgrip For This Useful Post:
johl (12-18-2016)
Old 12-20-2016, 04:48 PM   #12
COO86L
COO86L's Avatar
Drives: 2015 86 GTS + Mitsi Lancer GSR
It's a very good kit and the components included are excellent.
Last time I dyno'd on 16 PSI with the Borg Warner kit, I made 254kW on a 40C day fully heat soaked after a 2 hour drive. That was with stock front pipe and midpipe, blast pipe from axle. It would drop down to about 12 PSI by red line due to restrictive exhaust components.
I've since fitted a Blitz 2.75" catless front pipe and refitted the rear muffler and my 14.5 PSI boost level feels the same as what my 16 PSI setting does and I had to readjust boost control as I wasn't getting anywhere near the same taper at high RPM.
I also run stock wheels with not so decent tyres. Grip on 98 RON and 14.5 PSI is good but not great. Grip on E85 and any boost level is virtually non-existent.
I have DW 700CC Injectors which are at about 85% Duty Cycle on 18 PSI, DW 300C fuel pump, Competition Clutch Stage 4 (for the price in Australia, buy a Mantic), SME BW 6758 EFR kit 3" dump to 2.5" over pipe and the rest of the exhaust above.
To get the most out of the power now, I need to strengthen my drive shafts because they will go pop, run better tyres and pray to Jesus as I'm hammering the engine that it doesn't go bang.
COO86L is offline   Reply With Quote
Old 12-20-2016, 05:00 PM   #13
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Too Much:
When you can't afford to fix something when it breaks; because you went "all in" on the build.
I LIKE TIRES!
Old 12-20-2016, 05:33 PM   #14
-Phil
Drives: Rb25 neo brz
Anything over 400 is enough. Above that you get into useless power, more broken transmissions and more money spent.
-Phil is offline   Reply With Quote
The Following User Says Thank You to -Phil For This Useful Post:
ATL BRZ (12-21-2016)
Power By Max LCA's Thefear13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 03-16-2018 11:48 AM
***Blitz Advance Power Air Cleaner and SUS Power Core Intakes*** FT-86 SpeedFactory Engine, Exhaust, Transmission 1 10-07-2013 09:40 PM
What is your prediction on FT86 power and Subaru 086a power? 86Fan Scion FR-S / Toyota 86 GT86 General Forum 88 08-26-2013 11:49 PM
More power with Agency Power vividracing Engine, Exhaust, Bolt-Ons 0 07-26-2013 04:27 PM
