Old 12-06-2016, 02:01 AM   #1
tracerit
Drives: '13 SSM BRZ Limited 6MT
Is there a removable adhesive/putty that can withstand heat from the timing cover?
I'm getting what is most likely oil fizzing from the dipstick o ring that inserts into the front timing cover. I'd like to wipe the area clean and then put a wall of high temp adhesive or putty around the dipstick o ring hole (not in it) and see if it'll protect against the fizzing of the oil from there splashing back across the bottom of the timing cover as shown in the video.
https://goo.gl/photos/Ut1MA4DqccQtHgsB9
My next oil change isn't planned for another two months so I can't replace the O ring yet.
tracerit is offline   Reply With Quote
Old 12-06-2016, 11:15 AM   #2
stevesnj
stevesnj's Avatar
I don't think much oil would come out by replacing the o-ring now. I believe the end of the dipstick goes past where the o-ring is. But if you want to use a sealant for oil, the Black sealant is typically used for oil.
My 2016 Build thread
Timing Cover Oil Leak AllDayJonRay Issues | Warranty | Recalls / TSB 18 06-06-2016 03:12 AM
Timing Cover Oil Leak Keenercarguy Issues | Warranty | Recalls / TSB 66 05-30-2016 11:59 PM
Timing Chain Cover Leak alexand3r Engine, Exhaust, Transmission 17 09-29-2015 11:05 AM
Oil Leak from either Timing Cover or Valve Cover BRZY Issues | Warranty | Recalls / TSB 5 04-06-2015 08:31 AM
oil leak at timing cover choi0706 Issues | Warranty | Recalls / TSB 8 09-10-2014 06:25 PM
