Old 11-29-2016, 08:31 PM   #1
MatthewFRS
ECU Showing Throttle % ?
Hey guys, so now that I have an OBD2 Scan Tool, I was getting curious.
I got one of the WiFi ones that hooks up to your phone using an app, which I thought was nice. So I found a section in the app called 'Throttle', and I got curious. Checked it out, and it's exactly what it says it is. It's how much percentage the gas pedal is being pushed in. So without the car on, it said it was at 14.5% Throttle, and I pushed the gas pedal all the way in and it only got to about 80%.
Is that normal? Should it be going over 80 when pushed in, and below 14 when not pushed in at all? I know it can all probably be tweaked in the ECU, but I'm just wondering if this is limiting the performance of the car, or anything of the sorts. I'd love to hear back from some of you!
I'd also like to mention that I have no experience with the ECU, this was the first time I even found out you could use an OBD2 Scan Tool yourself, LOL.
Thanks in advance for the answers guys.
If anyone is wondering, it's a 2013 Auto Scion FRS
MatthewFRS is offline   Reply With Quote
Old 11-29-2016, 09:08 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
You're actually looking at the angle of the throttle plate/butterfly.
Old 11-29-2016, 09:12 PM   #3
TelMinz
Rotary for the win
Drives: BRZ, FD3S RX7
What Ultra said
"Behold, my field of phucks, lay thein eyes upon it, and notice, tis' barren."
TelMinz is offline   Reply With Quote
Old 12-06-2016, 09:11 PM   #4
Overdrive
Sittin' Sideways
Overdrive's Avatar
Drives: 2016 Toyota FR-S
I thought this is measuring the position of the throttle position sensor. Basically, the sensor needs to have a little wiggle room, and will never be fully at its own stops when the pedal is fully depressed (that 80-something %) or fully raised (the 14.5%). I could be wrong and it is indeed measuring the valve position after all, but I thought it was a measurement of the sensor travel.
-O/D
2016 FR-S, Hot Lava
Overdrive is offline   Reply With Quote
Old 12-06-2016, 11:26 PM   #5
Ultramaroon
not playing cards
Yup. That's pretty much it.
FA20 ENGINE CONTROL: SFI SYSTEM: DATA LIST / ACTIVE TEST; 2013 MY FR-S [03/2012 - ]
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
showing off some new parts Jhon19lopez Cosmetic Modification (Interior/Exterior/Lighting) 27 09-24-2013 10:53 AM
Used FR-S showing up on Cars.com xrs Scion FR-S / Toyota 86 GT86 General Forum 19 07-13-2012 10:46 PM
