Old 11-28-2016, 03:42 PM   #1
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Spare Tire Specs
Anyone know the width and offset of the OEM spare tire? Did a quick search, couldn't find anything, maybe I have to search harder when I have more time. Want to approximate a spacer size I'll need to fit it with my BBK.
Old 11-28-2016, 05:36 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
What size spacer is needed to fit a stock 17x7 with your BBK? I think it would be the same size spacer to make the spare fit.
Edit: Been thinking about this. Two things.
1. A 25mm or 30mm bolt on spacer should work.
2. The spare is going to be smaller diameter than your upgraded tires. Meaning if you get a flat on the rear, you should move a front wheel tire to the rear and put the spare on a front non-drive axle wheel. Different diameters are bad for the differential.
Old 11-28-2016, 05:44 PM   #3
FX86
What spare tire?
Old 11-29-2016, 01:30 PM   #4
kch
Senior Misanthrope
kch's Avatar
I don't have a full answer for you, but I can say the stock spare + 15mm spacer does NOT clear the AP sprint kit.
The Following User Says Thank You to kch For This Useful Post:
Leonardo (11-29-2016)
Old 11-29-2016, 05:17 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Stock spare was 16" or 17"? IIRC from few threads about space-saver spares there was also one 17" subaru spare that fit, maybe it may increase chances of BBK clearance?
Old 11-30-2016, 03:23 PM   #6
switchlanez
Called Subaru of America and they recited info from the users manual: 16x4T (not sure what T means), no offset info. Going to figure a needed spacer size from my BBK fitment template.
The Following User Says Thank You to switchlanez For This Useful Post:
Leonardo (11-30-2016)
Old 11-30-2016, 04:24 PM   #7
gramicci101
Off Topic
Can your BBK even fit in a 16" wheel, or will you need to push the wheel far enough out that the BBK completely clears it?
What about a 2004 (5x100) STI spare wheel? Those can at least clear the STI brembos, so they'll have a better chance of fitting your BBK. You could probably find one on eBay or NASIOC fairly cheaply.
Old 11-30-2016, 05:07 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
T is just like "J", rim contour / tyre bead profile shapes.
FS: OEM Spare Tire zeal86 Wheels and Tires 7 12-08-2016 09:37 AM
WTB: Spare Tire kanundrum Want-To-Buy Requests 2 11-15-2016 11:30 AM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 01:44 PM
Spare tire ??? Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-28-2014 06:46 PM
