Old 11-28-2016, 11:39 AM   #1
perryair
junior mafia
Drives: ‘20 sti limited
header swap vs. my 'green' side.
im thinking about installing an uncatted jdl uel header while keeping the rest of the exhaust stock. excited about the potential for a bit of subie rumble and the pickup in midrange and high end grunt but the eco friendly part of me is curious if the stock cat on the front pipe does any decent job of filtering out exhaust pollutants? don't know if anyone has explored that at all or actually tried to bring their similarly setup car through a sniffer test to see.
20 sti limited | 17 bmw m240i | 16 scion im |15 brz limited {prokit, 17x8 +35 rpf1, bfg comp 2 a/s, stg 2, jdl uel, voodoo knob} | 05 honda civic | 06 scion tc | 95 mustang gt | 89 chevy s-10 cameo
perryair is offline   Reply With Quote
Old 11-28-2016, 01:41 PM   #2
Teseo
Drives: frs
Go catless and let your grandchildren deal with the pollution. If you keep all exhaust components stock, will be quiet anyway
The Following 7 Users Say Thank You to Teseo For This Useful Post:
-Phil (11-28-2016), aagun (12-06-2016), D_Thissen (11-28-2016), gramicci101 (11-28-2016), meWant (11-30-2016), Reggaeboyz (12-01-2016), sugoi (11-28-2016)
Old 11-28-2016, 02:01 PM   #3
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Not gonna lie, I have thought about the environmental effects of being catless. Some times I think about putting a catted header on too, but I enjoy the sound and power of a catless header too much.
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
perryair (11-28-2016)
Old 11-28-2016, 02:24 PM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
The biggest part of the pollution will be when you first start the car. At cold startup, you're basically polluting about the same as a car from about 20 years ago before OBD-II.
After cold start you should have same tailpipe as a normal car and should pass tailpipe emissions should it be needed.
-alex
The Following 2 Users Say Thank You to mav1178 For This Useful Post:
Mr.Impreza (11-28-2016), strat61caster (11-28-2016)
Old 11-28-2016, 02:36 PM   #5
perryair
junior mafia
-alex
so the secondary cat is effective enough to bring emissions down to legal limits when warm? 👍🏻
The Following User Says Thank You to perryair For This Useful Post:
sato (12-04-2016)
Old 11-28-2016, 03:19 PM   #6
mav1178
mav1178's Avatar
Put it this way:
Aftermarket header/OP/FP systems with a high-flow catalytic converter emits less tailpipe than stock. Apex'i and HKS are two companies that offer this setup.
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
JDM4E (11-28-2016), Mr.Impreza (12-06-2016), sato (12-04-2016)
Old 11-28-2016, 04:32 PM   #7
JDM4E
Drives: Honda Accord Euro
Put it this way:
-alex
can you quote any measurement data?
JDM4E is offline   Reply With Quote
Old 11-28-2016, 07:40 PM   #8
lamawithonel
Drives: 2014 Subaru BRZ Ltd.
Not without modification. The front cat is the primary and the O2 sensors are positioned to manage it, not the secondary. The secondary cat is likely a two-way catalytic converter, as well, so it would need to be replaced with a three-way to see the same benefit.
But as others have stated, the real problem is the warm-up period. Even if you could move the O2 sensors back and replace the secondary with a three-way, it would still take significantly longer to warm up.
*question everything*learn something*answer nothing*
lamawithonel is offline   Reply With Quote
Old 11-28-2016, 07:52 PM   #9
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Put it this way:
I'm not sure about that. I had JDL catted header and catted front pipe (200 cell cats) and my car failed emissions test here in Aus.
Old 11-28-2016, 08:05 PM   #10
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Either install a header the car is dieing for or sell it and hug some trees with a Prius!
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
The Following 3 Users Say Thank You to GsxrMe For This Useful Post:
olsonpg (11-28-2016), PNW-BRZ (11-28-2016), Teseo (11-28-2016)
Old 11-28-2016, 08:30 PM   #11
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
If you care about the environment and don't want smell just leave at least 1 cat in the car.
In my 2002 Subaru WRX, we have 3 OEM cats. I removed all 3 and just had 1 200Cel cat in my downpipe.
Had no smell and no issues.
For this car I'd suggest Catted Header + Catless Front Pipe.
2018 Subaru WRX STI ~ The Weekend Car ~
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 11-28-2016, 09:45 PM   #12
cjd
cjd's Avatar
Drives: 2017 BRZ
Well, if you believe in government subsidies and the mess it creates to grow as much corn... which may still be better than gasoline, mind... try E85 for a greener burn.
And keep your eyes out for an available Tesla roadster.
Old 11-28-2016, 11:16 PM   #13
perryair
junior mafia
murica. bikinis. beer. football. powar. giggity.
thanks for the constructive input, those with it. i never knew about 2 vs 3 way cats and i guess just having the stock front pipe is something im comfortable with after the research.
Old 11-29-2016, 01:04 PM   #14
kch
Senior Misanthrope
kch's Avatar
Offset the increased emissions by running E85
The Following User Says Thank You to kch For This Useful Post:
G-awesome (12-05-2016)
Side Grill Swap JetSpeed BRZ First-Gen (2012+) — General Topics 3 05-15-2016 04:15 PM
Green wire on passenger side seat Ryaquinn Electronics | Audio | NAV | Infotainment 3 11-18-2014 09:17 PM
Replacement windshield with "green tint/green shade" extrashaky Scion FR-S / Toyota 86 GT86 General Forum 11 07-07-2014 11:02 AM
SWAP GTS86/FRS Side Vents for BRZ GTS86 Exterior Parts (Aero, Lighting, Etc.) 1 03-23-2013 03:01 AM
Side Vent Swap? Allankh CANADA 0 12-19-2012 02:26 PM
