Old 11-22-2016, 02:29 PM   #1
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
Can driver aids work after an engine swap?
Can anybody shed some light if it's possible to preserve Anti-lock brakes, traction and/or stability control after a swap? Has anyone done so?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 11-22-2016, 03:29 PM   #2
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Anything is possible with time and money
Old 11-22-2016, 03:54 PM   #3
Depends on the swap. Some different swaps have had pretty comprehensive ECUs developed. Some nothing.
Like Way said you got the cash somebody will come up with the action.
Old 11-22-2016, 03:59 PM   #4
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
The short answer is, for all practical intents and purposes, no not really.
The cost curve is extreme.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 11-22-2016, 04:09 PM   #5
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
sure. i have a factory cluster, abs, power steering, wheel speed sensors, custom traction control, factory gas pedal, factory fuel pump controller, etc. be ready to spend some money and find someone who can make it all work though.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 11-22-2016, 11:09 PM   #6
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
This is encouraging...
Money is not a huge issue
Talk to me about the ABS and traction control (I'm assuming you're running a stand alone)
Old 11-23-2016, 10:15 AM   #7
spitfire481
Drives: 2JZ FRS
Motec with custom firmware. Abs is same as stock, I haven't engaged it yet though but it is active. We setup the traction control for drag racing but you can do basically anything you want. this was our traction control setup on bare asphalt with the fa20 still in it. leaving on 18psi. pedal never left wide open
[ame="https://www.youtube.com/watch?v=amnb5LZclyk"]Motec fa20 traction control - YouTube[/ame]
MoTeC
Build Thread
@spitfire481
Old 11-28-2016, 11:18 PM   #8
MRS-Colin
Drives: 2001 Impreza 2.5 RS
A bit late to your post but:
I've done a few CAN based conversions in vehicles, so I feel like I have some experience here. Think of the car and its vehicle network as an algebra equation. A+B+C+D+E+F = WorkingCar
Remove E, you have WorkingCar-E.
The only extra bit about this would be that system A B C D and F rely on messages from system E. If you can replicate system E in all of its functions, the equation works again. This is all possible.
Why isn't it readily available? It takes time and time and time. Motec and others have put the time in and have gotten it all working. In a few years time when CAN based vehicles are more commonplace, this will be a non-issue. A good bit of people I talk to in the industry still really don't understand CAN.
Another thing to consider: Manufacturers are now more than ever cracking down on sharing information like the CAN .dbc file. After the recent attacks on FCA vehicles, information has gotten even more scarce. I know a good bit of Japanese manufacturers don't share the CAN format with their American counterparts. That leaves people like me to sit and stare at messages and poke and prod for hours to essentially "guess" it all correctly THEN make it work.
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 11-29-2016, 07:11 AM   #9
Calum
That Guy
Drives: 2013 asphalt FRS MT
I wonder if information would be available from these guys or someone similar.
http://jalopnik.com/the-fascinating-...d-o-1787205420
Obviously price would be a big factor, but it's food for thought.
Old 11-29-2016, 08:43 AM   #10
MRS-Colin
If you had an unlimited budget, yep.
Honestly if I had a better eye/brain for assembly there is plenty of documentation our there for disassembly of a BRZ ROM and I know where the CAN ID's are stored that I could probably figure out a bunch more, but disassembly isn't my strong suit.
Colin Beck
fr-s engine swap for less than $20k squizzbeat Engine Swaps 55 10-13-2025 09:46 AM
2JZ engine swap? s_king20 Engine Swaps 8 12-10-2015 03:09 PM
Engine swap JDM EJ25 STI engine FRSToyota86 Engine Swaps 25 11-20-2013 01:56 AM
Driver window controls don't work Hops Normal Issues | Warranty | Recalls / TSB 5 01-27-2013 08:35 PM
Engine Swap hybrid35 Southern California 0 01-07-2013 01:04 PM
