Old 11-08-2016, 09:20 AM   #1
JonnyQuest264
Drives: 4Runner & Motorcycles
89 Octane Ethanol Free vs 91 10%
Hey all, picking up my new (to me) 13 FR-S this week. Here in NE Florida we have a good supply of e-free gas, with one exception. It's 89 octane. I've been using it in my motorcycles with great results.
I know the minimum octane recommendation is 91 (US).
Is using the 89 octane e-free an option, even if maybe applying some OTC octane booster? Or should I stick with 91 octane 10%?
The car only has 22k miles, and the chirping TSB has already been taken care of. Just looking out for the future on my newly acquired investment.
Thanks!
JonnyQuest264 is offline   Reply With Quote
Old 11-08-2016, 09:27 AM   #2
Thanks!
I would stick to the 91 even if it has corn juice. The recommended rating is 93 the REQUIRED minimum is 91. Although you would not really hurt anything by running 89 the car will pull so much timing to prevent knock that you will take a large performance hit. Adding octane booster is not a replacement for using the proper octane in the first place.
Clipdat (11-08-2016), D_Thissen (11-08-2016), strat61caster (11-08-2016)
Old 11-08-2016, 10:14 AM   #3
D_Thissen
D_Thissen's Avatar
No..89 isn't an option.
The Following User Says Thank You to D_Thissen For This Useful Post:
Old 11-08-2016, 12:47 PM   #4
86Boyz
Drives: on the highway to hell
I used 89 a few times just for the heck of it when I was in Florida. It didn't make a difference in performance to me and probably shortened the life of the engine in the long run.
Buy 93 premium and stick with it. Shell V-Power Nitro+ is a great option.
86Boyz is offline   Reply With Quote
Old 11-08-2016, 01:07 PM   #5
Ya it will probably now only last 999,999,999,999.8 hours instead of 1,000,000,000,000.
Zhangy (11-12-2016)
Old 11-08-2016, 01:12 PM   #6
86Boyz
That's a big difference. It is as if you had a trillion dollars and were considered a trillionaire but now you are only a billionaire and are looked down upon and can't feed your family.
The Following 3 Users Say Thank You to 86Boyz For This Useful Post:
Chimera (11-08-2016), gramicci101 (11-08-2016), Tcoat (11-08-2016)
Old 11-08-2016, 03:56 PM   #7
gmanvilla1@gmail.com
gmanvilla1@gmail.com's Avatar
Drives: FRS
Or go with OFT tune and corn fuel. You will never go back.
gmanvilla1@gmail.com is offline   Reply With Quote
Old 11-08-2016, 04:06 PM   #8
humfrz
Hey all, picking up my new (to me) 13 FR-S this week. .........Thanks!
CONGRATULATIONS on your new purchase and WELCOME to ..... The Forum....
Yep, as generally recommended, use the highest octane gas available at your local gas station.
humfrz
Old 11-08-2016, 04:09 PM   #9
humfrz
...... you needed that ....... you're ah getten ...... that ah way again .....
humfrz
Old 11-08-2016, 04:21 PM   #10
humfrz
You mean correct?
humfrz (11-08-2016)
Old 11-08-2016, 04:47 PM   #11
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Strange. I use 93 and my timing gets pulled around 6k by a couple degrees. I couldn't imgaine 91, or even worse, 87. I'm glad our cars are capable of pulling timing, but it can only pull so much until knock happens. Even if the car seems to run fine, if you give it gas it surely won't. It fires and functions, but it won't run like it's supposed to, which can wear and damage components. I'm not sure if anyone here is aware of the spark plugs, but you do have to lift the engine to get all of them. Just an FYI, so run higher octane, i'd take 95 or even 100 if possible.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 11-08-2016, 04:50 PM   #12
Tokay444
Food for thought. Ethanol has an effective octane rating of 160 in a direct injection application.
Old 11-08-2016, 05:43 PM   #13
JonnyQuest264
humfrz
Thank you!
Pretty excited to pick it up tomorrow!
The Following User Says Thank You to JonnyQuest264 For This Useful Post:
Tcoat (11-08-2016)
Old 11-08-2016, 05:46 PM   #14
Cole
Not a troll
Cole's Avatar
Hahahaha hahahaha
Jesus Christ, does no one read the fucking manual anymore?
In regards to the fuel pump TSB, you'll get crickets again. Here's a very simple solution, instead of worrying about the noise your pump is making (which, let's be honest, is normal operation for it) try driving your car between 4 and 7 thousand RPM more often.
The Following 6 Users Say Thank You to Cole For This Useful Post:
Clipdat (11-08-2016), D_Thissen (11-08-2016), Mr.ac (11-08-2016), soulreapersteve (11-08-2016), strat61caster (11-08-2016), Tectoniic (11-08-2016)
90 octane ethanol-free fuel vs Shell 93 Nitro+ V-Power crickets BDKane01 Issues | Warranty | Recalls / TSB 11 06-09-2016 10:48 AM
Best Stations to fuel up that meet the 93 Octane less than 10% ethanol req. Concorazon Scion FR-S / Toyota 86 GT86 General Forum 58 10-30-2015 12:34 PM
Truth about gasoline, ethanol and octane?! Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 16 08-30-2014 08:04 PM
93 octane w/ethanol or 91 without existensil BRZ First-Gen (2012+) — General Topics 16 05-24-2014 07:32 PM
Higher Octane or Ethanol Free Chad86 Scion FR-S / Toyota 86 GT86 General Forum 1 03-28-2014 11:06 PM
